 @Alejandro3816
 Did you checked that the MD5 of each file all match? You may also use WinRAR and put all 3 dump files in a RAR compressed file, then open the RAR file and check that the CRC32 column (far right) values of all 3 files match.
 Once you have a verified "good" BIOS backup you just invalidate "SaDataBase" variable and save as a new file, just as I did:
 DO NOT USE my file until you are sure you have a good BIOS backup.Attached FilesComment
 The CRC32 is the same for all the files, I already flash the new .bin file you gave me and is working fine. Thank you very much.@Alejandro3816
 DO NOT USE my file until you are sure you have a good BIOS backup.  Comment
 Lenovo X390 8th need unlock please i try with lenovo patcher it give black screen and give beepsAttached FilesComment
 Please read the updated rules,the serial number/service tag etc must be posted
 .Comment
 tryAttached FilesComment
 hello there my bios is beeps continuesly then some music and blank screen
 my laptop lenovo thinkpad t490 i5 10th generation here is both my files Orignal and Patched
 https://www.drop********************...******63g&dl=0
 anyone have this fix?
 serial number pf-29ca45
 type number 20rx-s14700
 20/5
 compliance id tp00103a
 nm-b902
 rev 1.0
 ft490/ft492
 ft590/fp531
 d2001
 hsb
 is there any fixes?Last edited by SMDFlea; 10-29-2023, 03:54 AM.Comment
 Use the forum search for T490 threads and read,read,read - https://www.badcaps.net/forum/showth...ht=T490&page=3hello there my bios is beeps continuesly then some music and blank screen
 https://www***********************os063g&dl=0
 Attach files directly to your post instead of linking to external websites
 .Last edited by SMDFlea; 10-29-2023, 03:56 AM.Comment
 Hello new guy here
 Can someone verify my bios read?
 Lenovo x1 yoga gen1Comment
 i did it thanks for help laptop unlocked
 after clear bios password i fix the serial with lenovo-u1-tool-master
 Lenovo utility not working
 Steps :
 Extract n1ctm04w.zip and run usbfmtpw.exe
 Format the USB Drive
 Disconnect the USB Drive
 Extract u1u.zip (password for the zip is LenovoUone) and run u1.exe
 Reconnect the USB drive and hit run.
 Once the USB is created boot the USB Key and follow on screen instructions.
 UPDATE (30/07/2021) [Try this if above method fails.]
 I have Included a ZIP file containing all the script that Lenovo Uone tool uses to make the process simpler.Comment
 my dosent works... give me a sounded beep
 can i help?Attached FilesComment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
