https://www.badcaps.net/donate -
@Alejandro3816
Did you checked that the MD5 of each file all match? You may also use WinRAR and put all 3 dump files in a RAR compressed file, then open the RAR file and check that the CRC32 column (far right) values of all 3 files match.
Once you have a verified "good" BIOS backup you just invalidate "SaDataBase" variable and save as a new file, just as I did:
DO NOT USE my file until you are sure you have a good BIOS backup.Attached Filesif you find these attachements useful please consider making a small donation to the site
The CRC32 is the same for all the files, I already flash the new .bin file you gave me and is working fine. Thank you very much.@Alejandro3816
Lenovo X390 8th need unlock please i try with lenovo patcher it give black screen and give beepsAttached Filesif you find these attachements useful please consider making a small donation to the site
Please read the updated rules,the serial number/service tag etc must be posted
.Comment
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
hello there my bios is beeps continuesly then some music and blank screen
my laptop lenovo thinkpad t490 i5 10th generation here is both my files Orignal and Patched
https://www.drop********************...******63g&dl=0
anyone have this fix?
serial number pf-29ca45
type number 20rx-s14700
20/5
compliance id tp00103a
nm-b902
rev 1.0
ft490/ft492
ft590/fp531
d2001
hsb
is there any fixes?Last edited by SMDFlea; 10-29-2023, 03:54 AM.Comment
Use the forum search for T490 threads and read,read,read - https://www.badcaps.net/forum/showth...ht=T490&page=3hello there my bios is beeps continuesly then some music and blank screen
https://www***********************os063g&dl=0
Attach files directly to your post instead of linking to external websites
.Last edited by SMDFlea; 10-29-2023, 03:56 AM.Comment
SMDFlea
This laptop ( Lenovo X390 ) doesn't have any sticker behind there is no serial number or anyting
every thing removedAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello new guy here
Can someone verify my bios read?
Lenovo x1 yoga gen1Comment
i did it thanks for help laptop unlocked
after clear bios password i fix the serial with lenovo-u1-tool-master
Lenovo utility not working
Steps :
Extract n1ctm04w.zip and run usbfmtpw.exe
Format the USB Drive
Disconnect the USB Drive
Extract u1u.zip (password for the zip is LenovoUone) and run u1.exe
Reconnect the USB drive and hit run.
Once the USB is created boot the USB Key and follow on screen instructions.
UPDATE (30/07/2021) [Try this if above method fails.]
I have Included a ZIP file containing all the script that Lenovo Uone tool uses to make the process simpler.Attached Filesif you find these attachements useful please consider making a small donation to the site
my dosent works... give me a sounded beep
can i help?Attached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
