what to do when you don't have the supervisor password, and you get error 0183? model T490..
*** As I said, I don't have the supervisor password***Attached Filesif you find these attachements useful please consider making a small donation to the site
How about Press F1, change some setting in BIOS and save/reset?
also set the correct date and time.Comment
Hi everyone !
Can someone patch my L380 bios. I can not run patcher on my pc. Thanks alotAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello try this file ...
Good luck ...Attached Filesif you find these attachements useful please consider making a small donation to the site
still password :/ someone is tell me to flash ec chips but i can not find it on motherboardComment
Hi, i need a little help here. I have a P52 with a SVP. I have worked with the autopatcher before and made sure i have a valid dump.
In my first attempt i patched the dump and flashed it onto the CMOS. But all i got was a black screen and an error-melody after about one minute of waiting.
Then i read that i might need to clean the ME part of the bios. I followed the instructions on level1techs to clean the ME and patched the cleaned bios afterwards. But i had no luck with the cleaned+patched bios. The P52 was completly dead.
Maybe i made a mistake while cleaning the ME. Can someone clean (+patch) the attached dump?
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello try this me clean from your original Backup ...Hi, i need a little help here. I have a P52 with a SVP. I have worked with the autopatcher before and made sure i have a valid dump.
Thank you, but it didn't work. Again the error-melody. Does anyone has an idea what could be the problem. It seems others were able to unlock the p52 with 32m bios.Comment
Hello, I generally do it by removing the CMOS battery and before I start a
newly installed patch, I delete the NVRAM by short-circuiting the two pins of the
CMOS battery for a few seconds, so all capacitors and controllers are
discharged.
Just so my opinion has been very much preserved.Attached Filesif you find these attachements useful please consider making a small donation to the site
Newbie here....
1) How to do the BIOS dump and flash? Which software tool can be used for Lenovo laptop T480 BIOS?
2) A little confused about "Restore original BIOS". It means to restore the BIOS I dumped or need to download the original T480 BIOS from somewhere and restore/flash?
Thanks in advance.Comment
BIOS guides, methods, resources and tools
https://www.badcaps.net/forum/showthread.php?t=103526
Common SPI bios chip programming Questions and Answers
https://www.badcaps.net/forum/showthread.php?t=98665
Yes.
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
I know how to use the auto patcher software, my question is? is there anyway to decrypt the password out of a Yoga 370 bios dump, my only reason for asking is because i have about 100 of these all from the same company and probably all with the same password. Dump file is attached.Attached Filesif you find these attachements useful please consider making a small donation to the site
Is this the same company that you got those HP`s from ? .Have you tried contacting their IT department and asking them for the passwords,you never know you might be lucky.I know how to use the auto patcher software, my question is? is there anyway to decrypt the password out of a Yoga 370 bios dump, my only reason for asking is because i have about 100 of these all from the same company and probably all with the same password. Dump file is attached.
.Comment
Its not the same company where we got the HP's from. Unfortunately some of the companies we work with wont give us the password. We are an ITAD company who recycle laptops and computing equipment.Comment
Thanks @Vesko356.
Newbie updates:
1) How to dump the BIOS: need to get the Intel FPT (Flash Programming Tool). The Lenovo WinFlash can only update the BIOS, not for dumping. I found the Intel FPT from GitHub. Then run from the laptop CMD: FPTW64.exe -BIOS -D T480.bin
2) How to verify the BIOS dump: run from the laptop CMD: FPTW64.exe -BIOS -VERIFY T480.bin
3) How to patch: run the CMD: autopatch.cmd T480.bin
Got the Good Luck message and patched bin file
4) How to flash and replace the current BIOS with the generated patch file: I plan to use the CMD command: FPTW64.exe -BIOS -F T480_PATCHED.bin
Need to help on this step 4: is this step/command correct?
Thanks in advanceComment
Forget about all this useless exercise, and forget about any software method - not going to happen this (lazy) way. You need a bios programmer. Period.
Dump the bios, read post #1 and follow all how to instructions to do it.
Thanks @Vesko356 again
Now back to question zero: which one is the BIOS chip? I found there is 8-pin Winbond 25Q80DVSIG chip (at U15) near the C-MOS battery and 8-pin MXIC MX25L12873F at U49. Which one we need to work on (dump, patch and flash)?
ThanksLast edited by feb1234; 07-12-2023, 11:23 PM.Comment
Hello you need this one near the ram slot MXIC MX25L12873F at U49
it must be a 16,8 MB file. good luck ...Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
Yesterday, 05:52 PM -
- Loading...
