  • nuclearpunch
    • Jan 2023
    • korea
    #2181
    Try this ....
    thanks so much my friend
    • YYZBing
      • Jan 2023
      Hi All, I just Googled and found this active forum. Does auto patcher work on ThinkCentre tiny machine? I had the M920q 10RS machine supervisor password set long time ago and forgotten.
      • czeslavFu
        • Apr 2021
        • Poland
        #2183
        Hi
        seems it does not work with Lenovo y50-70 possibly due to the fact it does not prompt for any code just lock after third attempt with wrong password. Are there any tools for Y50 or tutorial how to "erase" the password from the bios? I have CH341a programmer and bios dump I could also solder/de-solder bios but looking for some tutorial what should be edited.
        Any hint/help welcomed - and yes I did searched the forum but found only request for y50 passw unlock and reply with unlocked bios but no hints how I can do it myself to learn sth. :-(
        • volinakis
          • Jan 2021
          • 2874
          • N/A
          #2184
          Originally posted by czeslavFu
          Hi
          https://www.badcaps.net/forum/showth...ghlight=Y50-70
          clean ME will do it ...
          • czeslavFu
            • Apr 2021
            • Poland
            #2185
            OK thx I will try it then.
            BTW shortening/connecting SCLK/SI pins (pin 6 & 5) of bios chip (U4) does work so I can enter the bios without the password but then cannot change it, anyway all other settings can be changed and saved :-)
            The sequence is: 1. use Lenovo key 2. then choose Enter Bios but before pressing Enter the pins need to be shorten/connected (I've just soldered wired switch for convenience) for a while and then Enter pressed and in this very moment pins should be disconnected.
            It needs some patience but worked 3 times in the row :-)
            • TTR
              • Apr 2020
              • 24
              • Poland
              #2186
              I can confirm that autopatcher does not work with Lenovo p52(8th gen).I read dump twice compare it using HXD.
              After patching and writing patched dump to eeprom i get nothing on the screen and laptop plays error melody.
              • casaba
                • Apr 2014
                • 25
                • morokko
                #2187
                tthanks
                • fr0n1k
                  • Feb 2020
                  • 5
                  • Russia
                  #2188
                  Can you, please help me remove supervisor password from L460? i've made patched file, but after flashing it, laptop doesn't boot with red F1 led. I've found some info, that this patch is not working with L460...
                  • Syserror
                    • Jan 2023
                    Just follow the first post, just did it on my L460
                    @Knucklegrumble --> THANK YOU!
                    • fr0n1k
                      • Feb 2020
                      • 5
                      • Russia
                      #2190
                      i've made it. After flashig Patched bios - RED led on F1, no boot. Re-flashed it with my dump, everything just fine (but still password). No idea what can be wrong...
                      UPD. Thanks for your reply. Re-made patch, removed ram, CMOS battery, flashed patched bios, installed ram - patch worked.
                      Thanks @Knucklegrumble and @Syserror
                      • Syavko1
                        • Mar 2022
                        • 53
                        • Ivano-frankivsk
                        #2191
                        Hello everyone, who can help unlock the bios
                        lenovo thinkpad l14 gen 1
                        • Monty83
                          • Sep 2021
                          • Suomi
                          #2192
                          Can somebody help me with X390 Thinkpad bios.
                          I think this one had older motherboard because this chip was readable with CH341A.
                          Tried autopatcher, but after booting laptop just gives contants beeps and flashes some caps lock etc lights.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12328
                            #2193
                            Try
                            • x3oo
                              • Jan 2022
                              • 10
                              • austria
                              #2194
                              I want to reset the password on my x380.
                              i did two reads and did a cmp on both of them. they are the same surprisingly because i had contact problems. Hope someone can help me. autopatch didnt work. anything else i have to do?
                              machine type model 20ljs1cj0f
                              • Monty83
                                • Sep 2021
                                • Suomi
                                #2195
                                Originally posted by hoaca388
                                Try
                                Same problem. Still beeping after programming that patched file.
                                That Thinkpad_X390.bin boots fine
                                • AAAC
                                  • Jan 2020
                                  • 458
                                  • Mexico
                                  #2196
                                  @Monty83
                                  I believe Autopatcher does not work on Thinkpad X390, as it has the Running BIOS and a Backup BIOS, "Self-Healing" prevents patch from working.
                                  • croccomp
                                    • 20
                                    Can anyone please help me remove supervisor password from x270? I've a patched file, but after flashing it, laptop doesn't boot. I've attached the original. cheers.
                                    • sanjay123
                                      • Aug 2018
                                      • 7
                                      • india
                                      #2198
                                      sombody help l480 remove password please
                                      • Sello2001
                                        • Dec 2022
                                        • 6
                                        • GER
                                        #2199
                                        Does somebody have a Lenovo P50 20EN bios without svp? I would really appreciate it.
                                        • straki007
                                          • Jan 2023
                                          • 6
                                          • Česko
                                          #2200
                                          Hi guys.
                                          I'm struggling here with my Thinkpad X250.
                                          Can't start after last night (apparently updates).
                                          My BIOS is locked and I don't know how to proceed with autopath.
                                          PORAD shows me that it saves the file, but it doesn't save it anywhere.
                                          Can you please help me unlock my BIOS?
                                          Thank you.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            Yesterday, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
