Fujitsu Stylistic Q616 Bios Dump
  • balint10
    • Aug 2020
    • 29
    • uk
    Hi All,
    Just brake my BIOS and dont have any back up of it to use with Flashrom.
    Does somebody have any BIOS dump of this tablet?
    Thanks in advance
  • balint10
    • Aug 2020
    • 29
    • uk
    Re: Fujitsu Stylistic Q616 Bios Dump
    Nobody have this tablet bios PLEASE
      • 20643
      What is the motherboard part number.Can you get any backup at all from the chip,what do you mean its broken ,how ?
      • balint10
        • Aug 2020
        • 29
        • uk
        The tablet is : Fujitsu Stylistic Q616 - M3-6Y30 900MHz 4GB RAM 128GB SSD (Fujitsu MAINBOARD M36Y304GB - FUJ:CP716030XX)
        I tried to upload the firmware BIOS 1.16, but when I restarted the Tablet just didnt start. When power up just a light black screen and every 5 sec restart itself. Dont let me to enter to BIOS either, only 1 beep and restart again.
        Unfortunatly didnt back up my BIOS before the flash. I have an IC Programmer and I can fflash the BIOS CHIP also I extracted the broken BIOS Binar file this time with FLASHROM.
        If somebody have a BIOS from the same Tablet I could flash to my BIOS CHIP.
        Thanks,
        Balint
          • 20643
          Backup the bios with your programmer and post it here.
          • balint10
            • Aug 2020
            • 29
            • uk
            Thanks for the fast reply.
            I uploaded my broken bios .bin file.
            The BIOS version I had before tha flash 1.08v
            Balint
            • Claudiomfa
              • Nov 2015
              • 455
              • Portugal
              try and report
              • balint10
                • Aug 2020
                • 29
                • uk
                I don't know if you are a magician or genius, but the fixed BIOS DUMP is working.
                The tablet boot up and running.
                Thanks you sooooo much
                • TacticalFahrrad
                  [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                  by TacticalFahrrad
                  I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                  06-30-2025, 04:09 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • EGUG
                  Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                  by EGUG
                  I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                  Serial number EICK023345
                  Mainboard D3823-A2
                  Hope somebody can help me.
                  04-10-2025, 02:05 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • grimacelord
                  Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                  by grimacelord
                  This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                  Motherboard model number: DA0PAMB46A1 REV: A
                  Secondary motherboard model number: 0PAB
                  SKU: 685K4UA
                  Serial number is: 5CD3223BJP
                  Recently reflashed this laptop with latest BIOS and once...
                  05-07-2024, 08:06 AM
