sir i tried it but only 2 blinking lights only i was usiang different bios ic because i dont want the original bios ic to be erase but when im trying to flash the new ic with the file with password its not working also do i really need to flash it in the original bios ic?
hp 6050A2728501-MB-A01 bios
Attached FilesLeave a comment:
Pls help me bios has password Hp Elitebook 840 g3
6050a2892401-mb-a01 bin
s/n 5cg8257ptyAttached FilesLeave a comment:
Re: hp 6050A2728501-MB-A01 bios
Serial number
https://www.badcaps.net/forum/showpo...9&postcount=47
i tried different bios, I didn't get results, thanks in advanceLeave a comment:
Serial number
.Leave a comment:
Hello, 4 blink lights are on, thank you.Leave a comment:
Hello, I have HP elitebook 840 g3 6050a2728501-mb-a01 power on led no display, blinking on keyboard, sometimes not power at all, the original bin is hereAttached FilesLeave a comment:
I will try it, thanks in adavanceLeave a comment:
your laptop is HP ELITEBOOK 840 G3
try these bin. i already tested this it works.Leave a comment:
.Leave a comment:
Hello, I have HP 840 G3 , 6050a2728501-mb-a01 ,bin file is needed, it power not displaying and it can't switch off only showing white power led .
This is the bios dump fileAttached FilesLeave a comment:
How to clean ME/TXE region -> https://www.badcaps.net/forum/showpo...41&postcount=3
.Leave a comment:
hello, need help. please clear ME, no display. thanks in advance.Leave a comment:
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by MDSIHello,
I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
Details:
Model : HP OMEN 17-an012nf
Motherboard Part Number : DAG3BAMBAF0 REV : F
Serial Number (S/N) : 5CD7280D51
BIOS chip : Winbond W25Q64VSIQ
Programmer : EZP2023+
Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
I already...-
by grimacelordThis laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
Motherboard model number: DA0PAMB46A1 REV: A
Secondary motherboard model number: 0PAB
SKU: 685K4UA
Serial number is: 5CD3223BJP
Recently reflashed this laptop with latest BIOS and once...-
- Loading...
