Asus fx553vd-dm029t power on lag 50 sec
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    The initial problem was black screen, i flashed bios + replaced thermal paste, now its working fine but i have 50 sec lag https://www.youtube.com/watch?v=sokZVL1xKL8
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Asus fx553vd-dm029t power on lag 50 sec
    post your bios backup
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      uploaded
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        i flashed GL553VD-AS.rar from here https://www.badcaps.net/forum/showpo...23&postcount=2
        • peste
          • Dec 2016
          • 12812
          • ROMANIA
          Originally posted by lordgeny
          try..
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            Originally posted by peste
            try..
            many thanks problem fixed .
            he was me region to clean ?
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
