MacBook Air unlock
  • lapfix
    • Mar 2020
    • 2714
    • my workshop
    MacBook Air unlock
    Hello folks , please unlock this bios..Thank you
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: MacBook Air unlock
    try and report
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • keats11
      T2 Macbook MDM Unlock by S/N change.
      by keats11
      I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
      05-15-2023, 06:46 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • Manlikeissak
      M1 MacBook EFI/FMM unlock
      by Manlikeissak
      Hello everyone hope you all are doing well, I'm posting here since no was interested in my post on "MacBook unlocked!" Topic, so In short I have found a way to test every possible key combination to try and find the combination to open the terminal on fmm/EFI locked M1/M2 machines, the person who found this still refuses to give info, but if hasn't lied about it being a key combination there's a chance we might find it, so to try Evey key combination I've got a digispark attiny 85 which is a small μController, I've written as script to emulate a keyboard and go thru every possible key...
      07-02-2024, 11:28 AM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
