Hp bdl50 la-d704p rev:1.0
  • ariful18
    • Aug 2016
    • 20
    • Bangladesh
    15-ay011TX BDL50 LA-D704/D703 rev 1.0
  • workgrup
    • Apr 2017
    • vsdfgj
    Re: hp 15 bios
    I need this dump urgently pls help
    HP 250 G5
    BDL50 LA-D704P REV: 4.0
    • ajmalkpr210
      • Nov 2016
      • india
      Re: bdl50 la-d704p rev:4.0 bios
      • unlockdev
        • 81
        Hp 250 bdl50 la-d704p rev 1.0
        Could any one help with
        LA-D704P REV 1.0 DIS BIOS
        amd gpu
        Thank you
        • Mcfalsi
          • Apr 2015
          • 192
          • Türkey
          bdl50 la-d704p rev:1.0 bİos dump need
          • lapfix
            • Mar 2020
            • 2724
            • my workshop
            Re: Hp bdl50 la-d704p rev:1.0
            Post your old dump
              • 20933
              https://www.badcaps.net/forum/showthread.php?t=84808 Post #1 has 4 different bios extracted from the HP bios update. Open your bios with a hex editor and search for the word BID ,that will give you the bios you need to use.
              https://www.badcaps.net/forum/showthread.php?t=67592
              • janaka
                • Dec 2020
                • 35
                • sri lanka
                Re: hp 15-ay011tx LA-D704P bios
                how i find D704 bin
                • setiyo
                  • Mar 2018
                  • 36
                  • Indonesia
                  thanksbrother
                  • erbuzzicker
                    • Apr 2018
                    • 42
                    • Italy
                    BL50 LA-D704P How to extract EC bios from Main Bios
                    Hello. Anybody knows how to extract EC firmware from Main bios? I have 8 MB main bios and I need to extract SIO bios because of SIO replacement. Thanks
                      • 20933
                      Re: How to extract EC bios from Main Bios
                      Laptop make and model number....... ?????????
                      • erbuzzicker
                        • Apr 2018
                        • 42
                        • Italy
                        HP 15-ay018nl
                        Motherboard BL50 LA-D704P Rev. 1.0
                          • 20933
                          Originally posted by erbuzzicker
                          HP 15-ay018nl
                          It can be copied from your bios backup using a hex editor.Post your backup
                          • erbuzzicker
                            • Apr 2018
                            • 42
                            • Italy
                            Here is it. Can you please explain me how to get it from BIOS? I already have HEX editor.
                              • 20933
                              Search for some words like ITE ,ENE,HARU,J7IFT
                              214000 -
                              • erbuzzicker
                                • Apr 2018
                                • 42
                                • Italy
                                Please, try to be more clear.
                                There are several parts of the file with the writing "ENE" (in this case): which of these to consider?
                                Once I found the correct one, what should I do to get only the part for the EC (I suppose it should be of 128 KB)?
                                • peste
                                  • Dec 2016
                                  • 12822
                                  • ROMANIA
                                  try this..
                                  use the HxD program..entert the bios in the program, type search..ENE ... KEY f3 UNTIL YOU REACH THE VALUE 214000 and then check 128kb or (20000) new copy-paste
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11741
                                    please, try to be more clear.
                                    There are several parts of the file with the writing "ene" (in this case): Which of these to consider?
                                    Once i found the correct one, what should i do to get only the part for the ec (i suppose it should be of 128 kb)?
                                    20000 = 128kb
                                    • erbuzzicker
                                      • Apr 2018
                                      • 42
                                      • Italy
                                      All clear now. Thanks guys
                                      • hennrri002
                                        • May 2022
                                        • 4
                                        • peru
                                        Thanks guys
                                        • zolie
                                          HP 15-AY023NH BDL50 LA-D702P REV 1.0 bios
                                          by zolie
                                          I need help with my bios. The bios will get stuck on startup. Thank you.
                                          HP 15-AY023NH
                                          BDL50 LA-D702P REV 1.0...
                                          06-21-2022, 07:10 AM
                                        • m041633n
                                          HP 15-be002tu BDL50 LA-D702P Rev 3.0 Power's On But No Display!
                                          by m041633n
                                          Tried Flashing the Bios from HP Website with CH341a Programmer
                                          (Extracted the BIN File using HP's "Copy BIOS image in order to use it on other devices" option)
                                          Tried the First One 081EC From the 5 BIN file's (081EC, 081ED, 081EF, 081F2, 081F3) which was extracted and decrypted already with the BIOS Update Utility from HP.
                                          But still the Same issue
                                          the Laptop's powering up, the HDD is not spinning nor the hdd led is blinking nor the Caps Lock led is blinking nor the cpu is heating, there is no display! Cleaned the RAM and the RAM Slot with IPA. Tested powering...
                                          12-31-2023, 04:04 PM
                                        • eniac22
                                          HP 250 G5 / BDL50 LA-D704P missing ACOK
                                          by eniac22
                                          Hi i have problem with HP 250 G5 / BDL50 LA-D704P no power / no light on charger led, the same problem with charged battery.
                                          I measured the following voltages with charger and without battery, i believe voltages is correct except ACOK.
                                          Pin 1 ACN : 19,4V
                                          Pin 2 ACP : 19,4V
                                          Pin 3 GMSRC : 19,4V
                                          Pin 4 ACDRV : 25,2V
                                          Pin 5 ACOK : 0V
                                          Pin 6 ACDET : 2,6V
                                          Pin 7 IOUT : 0V
                                          Pin 8 SDA : 0V
                                          Pin 9 SCL : 0V
                                          Pin 10 ILIM : 0V
                                          Pin 11 BATDRV : 0V
                                          Pin 12 SRN : 3,1V
                                          Pin 13 SRP : 3,1V
                                          Pin 14 GND : 0V
                                          01-12-2022, 08:16 AM
                                        • Renzo
                                          HP TPN-C125 BDL50 LA-D704p Rev 4.0
                                          by Renzo
                                          HP TPN-C125 BDL50 LA-D704p Rev 4.0 computer has a password on its bios, i have tried some other files that were for the same model, but still the computer isn't running.
                                          This is the original file, some one can help and clear it...
                                          09-25-2021, 12:48 AM
                                        • Renzo
                                          by Renzo
                                          HP TPN-C125 BDL50 LA-D704p Rev 4.0Hello my dear, your computer has a password on its bios, i have tried some other files that were for the same model, but still the computer isn't running.
                                          This is the original file, some one can help and clear it....
                                          09-23-2021, 05:41 AM
