HP 650 g5
  • TIXOU14
    GM
    • Aug 2020
    • 18
    • PARIS
    #81
    Re: help need unlock BIOS password HP 650 g5
    Originally posted by bbanana
    try this
    Model : HP Probook 650 G5
    SN : 5CG0197R84
    SKU : 5EG84AV
    BuilID : 19WWCOCT601#SUU#DUUG
    Board CT: PHWJU00WBDP20
    Featurebyte: 3X476J6S6b7B7H7M7QW7m7saBaEapaqauawbhcAdUdpdqfAfPhkk8.gE
    The sam problm the password is on
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      #82
      Unlocked
      • jcc2505
        • Apr 2023
        • 19
        • Tijuana
        #83
        HP 650 G5 Bios password
        Hi, i try unlock password with rc but still locked, can help please to unlock,
        board coconut 6050a3028501 mb a01
        SN 5cg015dyl7
        reques a hp authentication password or fingerprint from 3 different users to enter in Bios
        • aldopc
          • Jul 2017
          • 484
          • Chilito
          #84
          Re: HP 650 G5 Bios password
          SN 5cg015dyl7
          Hello, there is already a thread with this model, you should look for that thread.
          you can do it yourself with rcunlocker with your 16mb file https://www.badcaps.net/forum/showth...ght=rcunlocker
          • jcc2505
            • Apr 2023
            • 19
            • Tijuana
            #85
            Re: 650 g5
            i try but not remove for that reason i need help to unlock
            • hoaca388
              Badcaps
              • Jan 2022
              • 12441
              #86
              Re: 650 g5
              HP ProBook 650 G5 Notebook PC
              • Dieter68
                • 6
                • Deutschland
                #87
                I tried to read the BIOS chip from an HP Probook 650 G5 with a tl866ii reader - unfortunately without success. I always get an error message that the chip ID is incorrect. Since I suspected a problem with the reader, I bought a new EPROM of the same design. I can easily read and write this chip with the reader without any error messages. Then I unsoldered the original chip from the board and soldered the new chip on. After restarting the laptop, a BIOS recovery was automatically carried out. After that I could no longer read the new chip. Apparently the chip is changed again in such a way that it cannot be easily read. My question now would be what happened? Since a recovery was carried out, my question would be where is the backup on the motherboard? It can't be on the hard drive because I removed the drive. It would be great if you could help me here.
                Thanks and regards
                Dieter​
              • Dieter68
                • 6
                • Deutschland
                #88
                yes, of course, sorry.
                Unfortunately I currently only have the name HP Probook G5 with the serial number 5CG0359DS5. I couldn't find a number or type designation on the motherboard. But I'll check again to see if I can find anything there. But my main concern was whether there was something known about when the BIOS chip on the laptop itself uses the recovery function to change the chip in such a way that it can no longer be read with an eprom reader.
                greeting
                Dieter​
                • Dieter68
                  • 6
                  • Deutschland
                  #89
                  It is an HP ProBook 650 G5 Notebook PC (base model)
                  Product number
                  5EG86AV
                  The motherboard should be an L58731-601
                  • osman68i
                    • May 2015
                    • 357
                    • The Netherlands
                    #90
                    Product number
                    5EG86AV
                    firt backup and try this bios and ec.
                    I have tested and its working.
                    if not working check hardware
                    • Dieter68
                      • 6
                      • Deutschland
                      #91
                      I would like to do that but I don't know where the ec chip is on the board. Is there a picture where you can see the chip?
                      • osman68i
                        • May 2015
                        • 357
                        • The Netherlands
                        #92
                        check
                        • Dieter68
                          • 6
                          • Deutschland
                          #93
                          So far I've only tried to read the chip to the left of the main memory, but it doesn't work because I get an error message that an ID is not correct???
                          • ameerrrr
                            • Aug 2015
                            • 42
                            • syria
                            #94
                            I have a laptop HP ProBook 650 G5
                            It does not display
                            I want someone to edit the files for me With work clean me work
                            sn# 2TK102099S
                            • ameerrrr
                              • Aug 2015
                              • 42
                              • syria
                              #95
                              HP 650 G5 6050A3028501-MB-A01
                              fix HP Endpoint Security Controller Error Fix | HP Security Controller Problem
                              sn:2TK0470G2Y
                                SMDFlea commented
                                Editing a comment
                                Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12441
                              #96
                              sn:2TK0470G2Y
                              XXX
                              • ameerrrr
                                • Aug 2015
                                • 42
                                • syria
                                #97
                                Originally posted by hoaca388
                                XXX
                                Thank you very much it works
                                • techrecycle
                                  • Jan 2024
                                  • 64
                                  • england
                                  #98
                                  please remove bios password
                                  5CG9528652
                                  • techrecycle
                                    • Jan 2024
                                    • 64
                                    • england
                                    #99
                                    HP 650 G5
                                    Bios password locked
                                    sr: 5CG9520SF6
                                    please help to unlock thanks
                                      • 22275
                                      Originally posted by techrecycle
                                      HP 650 G5
                                      sr: 5CG9520SF6
                                      Have you tried RCUnlocker ?
                                      BIOS guides, methods, resources and tools
                                      https://www.badcaps.net/forum/troubl...rces-and-tools
                                      • Soumana Sanou
                                        “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                        by Soumana Sanou
                                        Hello,😇😇😇
                                        I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                        🔧 Model: HP ProBook 11 G2
                                        📦 Serial Number: 8CG72478MY
                                        🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                        🔒 BIOS Status: Locked with password
                                        The laptop is no longer under warranty and HP refused to help me.
                                        I’m looking for a custom SMC.bin file.
                                        I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                        Thanks a lot for your help!🙏🙏🙏...
                                        06-17-2025, 04:04 PM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                        HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                        This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                        09-07-2024, 05:50 AM
                                        HP ProBook Probook 650 G4 Notebook 600 Specification for Upgrade or Repair
                                        This specification for the HP ProBook Probook 650 G4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Probook 650 G4 boardview and Probook 650 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 06:51 AM
