HP 650 g5
  • hirens
    • May 2022
    • 187
    • uganda
    #61
    Re: HP Pro- Book 650 G5 help clean me region
    Try the files, hope it works fine.
    hey the 32 mb file works with quick display, but the challenge is it brings manufacture programing mode is in unlock mode 32 it keeps restarting with out any continuation while the 32 times keep on counting to zero.
    so the major problems are
    1. keeps on restarting
    2. manufacture programing mode is in unlock mode
    kindly help me clear the errors
    • Pcandu
      • Mar 2020
      • 7
      • SRB
      #62
      Re: 650 g5
      Hello!
      Can anyone help with what I assume is corrupted bios?
      Laptop originally booted fine,but had bios password which I tried to unlock. I soldered wires to the 32mb chip and tried to read it, unfortunately I forgot to disconnect main battery and laptop tried to power up while reading chip content. After removing wires from the chip and trying to power on laptop, it no longer posts, just fans spinning and no picture. ( I also realised that I neeed to use unlocker only on the 16mb chip, so I didn't need to mess with 32mb chip at all. )
      Later I desoldered both 32 and 16mb chips, read and saved the contents.
      If anyone can take a look at them and see if they can be fixed I would greatly appreciate it.
      • sabri farid
        • Jan 2019
        • 29
        • maroc
        #63
        Re: 650 g5
        hi i need remove password bios hp probook 650 g5
        6050A3028501-MB-A01
        thanks in advance
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #64
          Re: 650 g5
          6050A3028501-MB-A01
          thanks in advance
          First of all the dump is corrupted, what is your programmer?
          Secondly you've dumped the wrong chip. Find 16MB nand, dump the content, use verification and make sure you've read the chip properly then use RCUnlocker to remove the password.
          Become a Badcaps supporter
          Thanks to all supporters.
          • sabri farid
            • Jan 2019
            • 29
            • maroc
            #65
            Re: 650 g5
            thank you for resuming
            TL866II PLUS programmer
            • sabri farid
              • Jan 2019
              • 29
              • maroc
              #66
              Re: 650 g5
              6050A3028501-MB-A01
              thanks in advance
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #67
                Re: 650 g5
                6050A3028501-MB-A01
                thanks in advance
                Do you speak English?! I said - use RCUnlocker to remove the password:
                • sabri farid
                  • Jan 2019
                  • 29
                  • maroc
                  #68
                  Re: 650 g5
                  I have already try it and it didn't work
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #69
                    Re: 650 g5
                    Do it again, because I just used successfully the tool to patch your dump, and RCUnlocker do the job as it should.
                    • futadmytro
                      • Aug 2020
                      • 67
                      • Сполучені Штати
                      #70
                      hp 650 g5 bios password
                      Pleace help to unlock
                      Thank you
                        • 22275
                        Re: hp 650 g5 bios password
                        Thank you
                        BIOS guides, methods, resources and tools
                        https://www.badcaps.net/forum/showthread.php?t=103526
                        3. Password removal by laptop brand
                        https://www.badcaps.net/forum/showpo...42&postcount=4
                        • josebml
                          • Nov 2015
                          • 40
                          • spain
                          #72
                          Re: 650 g5
                          Hello
                          I have aHp 650 G5 computer with the message of:
                          Hp endpoint security controller problem
                          You can be removed this message?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12438
                            #73
                            Re: 650 g5
                            Originally posted by josebml
                            Hello
                            Ofcouse
                            • Dave Beck
                              • Aug 2018
                              Re: 650 g5
                              Hi
                              Is there someone who could remove the "HP endpoint security controller problem" from these dumps?
                              Thanks for your time.
                                • 22275
                                Re: 650 g5
                                Originally posted by Dave Beck
                                Hi
                                Compare the files at posts 72 & 73 with a hex editor or file comparison software
                                • Dave Beck
                                  • Aug 2018
                                  Re: 650 g5
                                  Thanks for your help, the HP Endpoint warning has gone but I now have a slow boot due to ME Corruption.
                                  What is the best approach to solve the ME issue .. Bios shows ME Ver 0000.
                                  Thanks again for your time.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12438
                                    #77
                                    Re: 650 g5
                                    Clear ME bios.
                                    https://www.badcaps.net/forum/showpo...41&postcount=3
                                    • Dave Beck
                                      • Aug 2018
                                      Re: 650 g5
                                      Help needed.
                                      Trying to get ME Analyzer to load the combined bin files from an HP 650 G5 and I get an error, same with the correct FIT. If I read a single chip Bios (HP 650 G2) all works fine so it must be the combined Bin file at fault. I made the combined file using the .bat script as detailed in the ME Firmware Cleaning Guide ... Any ideas ?
                                      • TIXOU14
                                        GM
                                        • Aug 2020
                                        • 18
                                        • PARIS
                                        #79
                                        help need unlock BIOS password HP 650 g5
                                        this is my dump
                                        • bbanana
                                          Father Land
                                          • Oct 2021
                                          • 164
                                          • Vietnam
                                          #80
                                          Re: help need unlock BIOS password HP 650 g5
                                          this is my dump
                                          try this
                                          Model : HP Probook 650 G5
                                          SN : 5CG0197R84
                                          SKU : 5EG84AV
                                          BuilID : 19WWCOCT601#SUU#DUUG
                                          Board CT: PHWJU00WBDP20
                                          Featurebyte: 3X476J6S6b7B7H7M7QW7m7saBaEapaqauawbhcAdUdpdqfAfPhkk8.gE
                                          • Soumana Sanou
                                            “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                            by Soumana Sanou
                                            Hello,😇😇😇
                                            I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                            🔧 Model: HP ProBook 11 G2
                                            📦 Serial Number: 8CG72478MY
                                            🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                            🔒 BIOS Status: Locked with password
                                            The laptop is no longer under warranty and HP refused to help me.
                                            I’m looking for a custom SMC.bin file.
                                            I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                            Thanks a lot for your help!🙏🙏🙏...
                                            06-17-2025, 04:04 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
                                            HP ProBook Probook 650 G4 Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP ProBook Probook 650 G4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Probook 650 G4 boardview and Probook 650 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 06:51 AM
