HP 650 g5
  • hoaca388
    Badcaps
    • Jan 2022
    • 12438
    #41
    Re: 650 g5
    Originally posted by josebml
    The problem is I have several identical computers, this one did not boot with its bios, I made this backup and then I recorded a bios from the internet and it started but it did not give an image, this is the only backup I have of the original bios, it is possible that was damaged.
    Can't do anything if it's damaged?
    Now I will upload the one from another computer that did start and the error message appears:
    Hp endpoint security controller problem
    Post this file.
    • josebml
      • Nov 2015
      • 40
      • spain
      #42
      Re: 650 g5
      Attached the bios of another computer that gives the same error:
      hp endpoint security controller problem
      • hoaca388
        Badcaps
        • Jan 2022
        • 12438
        #43
        Re: 650 g5
        "HP endpoint security controller problem" fixed.
        • josebml
          • Nov 2015
          • 40
          • spain
          #44
          Re: HP BIOS unlock tool
          Good afternoon,
          I have several Hp 650 G5 computers with the message of:
          I am attaching the bios of one of them to see if the message it gives can be removed.
          I tried with an internet backup to program the two chipsets and in the first reboot reset the security values, but the error keeps coming out.
          Thank you
          Thanks very much
          And nothing can be done about this other?
          • hoaca388
            Badcaps
            • Jan 2022
            • 12438
            #45
            Thanks very much
            After resetting information such as serial number, product number...will the machine restart automatically? And during that boot do you keep pressing F10, go to bios settings to disable security options?
            • josebml
              • Nov 2015
              • 40
              • spain
              #46
              Re: 650 g5
              I get a feature byte error, how can I extract it from the old bios?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12438
                #47
                Re: 650 g5
                Your fearture byte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdUdpdqfPhkk8.TH
                Your Build Id : 19WWCOCT601#SAK8#DAK8
                • josebml
                  • Nov 2015
                  • 40
                  • spain
                  #48
                  Re: 650 g5
                  Thank you,
                  it's already working.
                  My question is that if the bios that I uploaded first had the 16mb file damaged, can it not be fixed?
                  Or can I use this bios that you have fixed for both computers?
                  • josebml
                    • Nov 2015
                    • 40
                    • spain
                    #49
                    Re: 650 g5
                    Hi, sorry for insisting, these are the files that I uploaded from the first computer, you told me that the 16mb one was damaged, is it possible to fix it?
                    • josebml
                      • Nov 2015
                      • 40
                      • spain
                      #50
                      Re: 650 g5
                      Is there any solution?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12438
                        #51
                        Re: 650 g5
                        This 16 MB file cannot be repaired, you can use a working machine of the same type.
                        • hirens
                          • May 2022
                          • 187
                          • uganda
                          #52
                          HP Pro- Book 650 G5 help clean me region
                          hello guys some one help me clean me region
                          machine takes long to boot up.
                          it first blinks caps 5 times every time there's a restart then the display comes next.
                          laptop is HP Pro- Book 650 G5
                          SN: 5CGO527PM
                          board number: coconut-6050A3028501-mb-a01(A1)
                          machine also has some error on startup hp endpoint security controller problem.
                          Attached are the dumps that work. i got them from somewhere i don't remember but they are the only ones working on the laptop.
                          the only problem is slow start up
                          thanks
                          Last edited by SMDFlea; 01-31-2023, 08:56 AM. Reason: renamed title from "help clean me region"
                          • hirens
                            • May 2022
                            • 187
                            • uganda
                            #53
                            Re: 650 g5
                            any help on my files i posted please.
                            the files here all don't display with this machine. except the ones i posted
                            they just run fans but no display
                            • hardware1
                              • Sep 2021
                              • 2949
                              • N/A
                              #54
                              Re: HP Pro- Book 650 G5 help clean me region
                              SN: 5CGO527PM
                              thanks
                              Try the files, hope it works fine.
                              all donations are welcome,
                              • mOri
                                • Jan 2014
                                • 23
                                • england
                                #55
                                Re: 650 g5
                                Hi everyone
                                I got a hp 650 g5
                                Windows 8 and old 10 can be installed but when I try to install new windows 10 or windows 11 it gets stuck after the first restart.
                                I tried other bios dumps it works but the laptop becomes very slow
                                can anyone help me fix my bios dump files, please
                                • Kodza
                                  • Jun 2016
                                  • 194
                                  • South Africa
                                  #56
                                  Re: 650 g5
                                  Hello I got hp 650 g5 with computrace help remove , Thanks
                                  • ogre4273
                                    • Mar 2022
                                    • 57
                                    • N/A
                                    #57
                                    Re: 650 g5
                                    try this and feedback
                                    • aminealae
                                      • Jun 2013
                                      • 97
                                      • morocco
                                      #58
                                      Re: 650 g5
                                      Probook 650 g5
                                      turn on but black screen please if anyone can help me
                                      thank you advance
                                      • aminealae
                                        • Jun 2013
                                        • 97
                                        • morocco
                                        #59
                                        Re: 650 g5
                                        Originally posted by aminealae
                                        Probook 650 g5
                                        thank you advance
                                        anyone can help me please
                                        • hardware1
                                          • Sep 2021
                                          • 2949
                                          • N/A
                                          #60
                                          Re: 650 g5
                                          Probook 650 g5
                                          thank you advance
                                          Here's your New BIOS, try it and let me know.
                                          Serial Number: 5CG9392436.
                                          • Soumana Sanou
                                            “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                            by Soumana Sanou
                                            Hello,😇😇😇
                                            I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                            🔧 Model: HP ProBook 11 G2
                                            📦 Serial Number: 8CG72478MY
                                            🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                            🔒 BIOS Status: Locked with password
                                            The laptop is no longer under warranty and HP refused to help me.
                                            I’m looking for a custom SMC.bin file.
                                            I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                            Thanks a lot for your help!🙏🙏🙏...
                                            06-17-2025, 04:04 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
                                            HP ProBook Probook 650 G4 Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP ProBook Probook 650 G4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Probook 650 G4 boardview and Probook 650 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 06:51 AM
