Panasonic CF-20 Bios Password
https://www.badcaps.net/donate -
I did. Screen pgoto just demonstrated firmware update error after soldering BIOS back.Main promlem did not solved and I can use internal SATA only with another BIOS dump from this thread: https://www.badcaps.net/forum/troubl...41#post3298641 . Anyway I still have to inject an ME region manually.Comment
Hello, I apologize for bothering you, can someone help me and unlock this CF-20 bios?Attached FilesComment
https://www.badcaps.net/donateComment
Originally posted by kd9THX I apologize, the model is CF-20C5-00VM AND THE SERIAL IS 8BKKA68300
Attached Files↵
Thank you very much for the help, it is functional - I have another question: I have 2 more cf-20s that no longer display anything on the display, not even through hdmi, they boot . I think it is a problem with the intel ME driver, can something be done with them to solve the problem. Thank you once again.Comment
Thank you very much for the help, it is functional - I have another question: I have 2 more cf-20s that no longer display anything on the display, not even through hdmi, they boot . I think it is a problem with the intel ME driver, can something be done with them to solve the problem. Thank you once again.↵
Hello there .I need remove bios password .Model CF-20G55184VM s/n 8DKKA77969 .Thank youAttached FilesComment
Hello, I apologize for bothering you, maybe you can help me with some advice, I lack experience in this field. Unfortunately, the bios of a Panasonic CF-20 Toughbook has failed, I have an image of another model, and changing the physical chip, it works, but on Intel it shows 0.0.0.0 and I can't update that file, I also haven't been able to change the serial and series number (to be like the one with the defective chip) the boot time is very high, over 40 seconds. I'm changing it, but after I turn it on, the OS tells me that it doesn't look like a Panasonic device. Could someone edit my chip with Intel Me firmware and a different serial number?. Have a nice day.
post the contents of the bios chip even if it is corrupted..(original bios + delayed bios)...
Every donation made will go towards server fees and maintenance costs.Comment
My CF-20 dead after flashing bios in Windows with afuwin. I see only one way restring bios with programmer .Bad for meComment
Hi please can the password be removed from this bios, Thanks
Model code: CF-20C5108T2
Serial: 8AKCA61892
Attached Files↵
Hello, I have a CF-20 that has no image/no boot. If anyone can point me for a good BIN so I can reflash it. Here's the original DUMP.Attached FilesComment
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
Channel: BIOS Requests ONLY!
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
- Loading...
