Panasonic CF-20 Bios Password
  • hoaca388
    Badcaps
    • Jan 2022
    • 12240
    #41
    Originally posted by Anzo Matrix
    Need help... BIOS is not locked, system starts and perfectly works from USB but device hangs during POST if any SSD presents in its M.2 slot inside the case instead of connecting via USB3 and USB-M2 adapter as I have to work for now.
    This issue has appeared after macOS update (yes, a third system on it is Hackintosh).
    First time I've got this problem after same action - the seller simply changed a whole device by warranty. I've thought it was a hardware problem with SATA controller. So now I think that system updater rewrote some UEFI areas - CMOS battery removing didn't help. BIOS update program fails with unknown error (code 999 IIRC).
    Panasonic CF-20mk2
    Model CF-20G5-05VM as printed on label (or CF-20G5108VM / CF-VEK206LM as shown in BIOS setup)
    Serial 9FKKC22343 as printed (2nd serial in BIOS setup after slash is 9FKKC22328)
    Serial : 9FKKC22343
    • Anzo Matrix
      • Jun 2024
      • 4
      • not Florida
      #42
      Originally posted by hoaca388
      Serial : 9FKKC22343
      Flashed back. Totally same.
      Flash update error looks like this.
        SMDFlea commented
        Editing a comment
        You must flash the bios with an SPI programmer
    • Anzo Matrix
      • Jun 2024
      • 4
      • not Florida
      #43
      I did. Screen pgoto just demonstrated firmware update error after soldering BIOS back.Main promlem did not solved and I can use internal SATA only with another BIOS dump from this thread: https://www.badcaps.net/forum/troubl...41#post3298641 . Anyway I still have to inject an ME region manually.
      • kd9
        • Mar 2025
        • 6
        • Romania
        #44
        Hello, I apologize for bothering you, can someone help me and unlock this CF-20 bios?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12240
          #45
          Add model and serial number to post.
          • kd9
            • Mar 2025
            • 6
            • Romania
            #46
            I apologize, the model is CF-20C5-00VM AND THE SERIAL IS 8BKKA68300
            • hoaca388
              Badcaps
              • Jan 2022
              • 12240
              #47
              THX I apologize, the model is CF-20C5-00VM AND THE SERIAL IS 8BKKA68300
              Unlocked
              • kd9
                • Mar 2025
                • 6
                • Romania
                #48
                thx I will test it and replay.
                • kd9
                  • Mar 2025
                  • 6
                  • Romania
                  #49
                  Unlocked
                  Thank you very much for the help, it is functional - I have another question: I have 2 more cf-20s that no longer display anything on the display, not even through hdmi, they boot . I think it is a problem with the intel ME driver, can something be done with them to solve the problem. Thank you once again.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12240
                  #50
                  Maybe
                  • Igor Shell
                    • Oct 2024
                    • 7
                    • Kazakhstan
                    #51
                    Hello there .I need remove bios password .Model CF-20G55184VM s/n 8DKKA77969 .Thank you
                    • shiyab
                      • Sep 2023
                      • 1588
                      • india
                      #52
                      hi try
                      • Igor Shell
                        • Oct 2024
                        • 7
                        • Kazakhstan
                        #53
                        Thank you will do it in Monday only
                        • kd9
                          • Mar 2025
                          • 6
                          • Romania
                          #54
                          Hello, I apologize for bothering you, maybe you can help me with some advice, I lack experience in this field . Unfortunately, the bios of a Panasonic CF-20 Toughbook has failed, I have an image of another model, and changing the physical chip, it works, but on Intel it shows 0.0.0.0 and I can't update that file, I also haven't been able to change the serial and series number (to be like the one with the defective chip) the boot time is very high, over 40 seconds. I'm changing it, but after I turn it on, the OS tells me that it doesn't look like a Panasonic device. Could someone edit my chip with Intel Me firmware and a different serial number?. Have a nice day.
                          • peste
                            peste commented
                            Editing a comment
                            post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                        • peste
                          • Dec 2016
                          • 13350
                          • ROMANIA
                          #55
                          post S/N, full name and model, motherboard model, etc.
                          post the contents of the bios chip even if it is corrupted..(original bios + delayed bios)...
                          • Igor Shell
                            • Oct 2024
                            • 7
                            • Kazakhstan
                            #56
                            My CF-20 dead after flashing bios in Windows with afuwin. I see only one way restring bios with programmer .Bad for me
                            • Igor Shell
                              • Oct 2024
                              • 7
                              • Kazakhstan
                              #57
                              Maybe anyone know location bios chip ? Thanks
                              • Dave Spiby
                                • May 2025
                                • United Kingdom
                                #58
                                Hi please can the password be removed from this bios, Thanks
                                Model code: CF-20C5108T2
                                Serial: 8AKCA61892
                                  SMDFlea commented
                                  Editing a comment
                                  Thread merged.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12240
                                #59
                                Serial: 8AKCA61892
                                Password removed
                                • trenkov
                                  • Jun 2014
                                  • 6
                                  • bulgaria
                                  #60
                                  Hello, I have a CF-20 that has no image/no boot. If anyone can point me for a good BIN so I can reflash it. Here's the original DUMP.
