LENOVO 330-141gm need to fix
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Laptop came dead and bios chip is corrupted ,cannot take bakcup but i found a bios here in this forum, flashed now there is a light but turns on light show and goes off, i will try to flashed with clean bios, here in the dump i got here in this forum.Can someone fix this bios please
    • 22279
    Re: LENOVO 330-141gm need to fix
    Post the link to the bios you got .
    • String2016
      • Nov 2015
      • 2242
      • philippines
      here is the link https://www.badcaps.net/forum/showth...hlight=NM-B661 i tried post #4
      • String2016
        • Nov 2015
        • 2242
        • philippines
        can someone clean the me region on this please
        • String2016
          • Nov 2015
          • 2242
          • philippines
          and also I need ec on this the board has ITE8986E
            • 22279
            That one at post 4 has a corrupt ME region,the one linked by peste at labone is initialised (open it with MEAnalyzer) ,which means that the ME region is "dirty" and would need cleaning.
            • String2016
              • Nov 2015
              • 2242
              • philippines
              @smdflea please post here the clean file thank you
                • 22279
                Here. Extracted from bios update 7XCN37WW, DMI info from labone bios.
                D 483000 - 484FFF
                • String2016
                  • Nov 2015
                  • 2242
                  • philippines
                  tried replacing with new chip and flashed with smdfea bios still same issue turns on after a 5seconds turns of then goes on again with no display. maybe this is not a bios issue but thanks smdflea
                  • menshawy
                    • Aug 2013
                    • 400
                    • egypt
                    D 483000 - 484FFF
                    thanks
                    working ok with 330 -15IGM-nm-b661
                    • rein2017
                      • Jun 2017
                      • 35
                      • Philippines
                      Thank bro its working
                      • pcnetch
                        • Aug 2013
                        • 125
                        • Sri Lanka
                        working. thanks
                        • rennaruki
                          • Oct 2021
                          • 12
                          • Indonesia
                          D 483000 - 484FFF
                          thank you very much!
                          • dexter_kevin
                            • Sep 2017
                            • 23
                            • Sri Lanka
                            D 483000 - 484FFF
                            Thanks..Working 100%
                            • TylerHyde21
                              Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                              by TylerHyde21
                              Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                              I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                              I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                              This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                              06-29-2024, 10:38 AM
                            • lucaszmn
                              by lucaszmn
                              Problem:
                              Initial Findings:
                              • I concluded that the
                              08-12-2025, 03:01 PM
                            • to5it0
                              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                              by to5it0
                              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                              I have opened the laptop and identified the main BIOS chip...
                              10-24-2025, 01:35 AM
                            • BlueNitesFire
                              I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                              by BlueNitesFire
                              So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                              03-08-2025, 03:49 PM
                            • FalconPunch
                              Surface Pro X 1876 Bios corrupted
                              by FalconPunch
                              Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                              Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                              08-09-2025, 03:56 AM
