15-dh0904nz bios
  • GSM MULTIMEDIA PRO
    • Jun 2020
    • 9
    • Spain
    15-dh0904nz bios
    i have a HP Omen model number 15-dh0904nz
    i have add a power-on password .
    just make the update of the bios ,now the pc dont start tell me wrong password
    now i dump the bios .with SVOD3 .the bios have same size of the bios in hp support site
    pls can any one help to unlock it
    • 20695
    Re: HP BIOS unlock tool
    Your bios is corrupt. Download the bios update from HP: https://support.hp.com/us-en/drivers...model/29625666 .Run the EXE and make a USB recovery drive. Try the recovery method first,if it doesn`t work run the exe again,select copy. There are 4 different bios, yours is 08600.bin (or copy it from the recovery drive) .You will lose DMI info by flashing a virgin bios and youll need to use HP BCU bios config utility,or nbdmifit to add the missing info ,serial etc .
      • Jun 2020
      • 9
      • Spain
      Re: 15-dh0904nz bios
      thanks a lot
      al ready done pc now starting with unlock manifacturing but like you tell me have no data now hve to use BCU to get data back
      thanks a lot
      can we get from the corrupted bios all info we need ????
      Last edited by GSM MULTIMEDIA PRO; 07-18-2020, 08:29 AM. Reason: forgot to add some txt
      • peste
        • Dec 2016
        • 12652
        • ROMANIA
        thanks a lot
        thanks a lot
        try this..
        https://www.youtube.com/watch?v=9T57ktw8n3Y
          • 20695
          thanks a lot
          thanks a lot
          All the info you need is on the sticker on the case or in the battery compartment ,you can look through the old bios as well with a hex editor. See this video for HP BCU https://www.youtube.com/watch?v=r2ubpyeUOB4
          EDIT: If you can use a hex editor you can copy the DMI info from the old bios, 351000 - 351FFF (length 1000)
            • Jun 2020
            • 9
            • Spain
            thanks a lot for your help
            i have programmed the bios with the info i have onstickers of laptop
            but UUID and CT can not found this info
            can you help pls for that??
            thanks for all
              • 20695
              Your bios + DMI
                • Jun 2020
                • 9
                • Spain
                big thanks all done
