Hp 430 g3 probook
  • vikivng
    • Feb 2019
    • 216
    Hp 430 g3 probook
    Hi guys,
    I have been trying to create a bios recovery usb for this machine.
    However i am either getting no option to create the usb or getting a message telling me the bios is corrupted.
    Can anyone help.?
  • Bonzas
    • 469
    • Indonesia
    Re: Hp 430 g3 probook
    What problem on your laptop ?
    • vikivng
      • Feb 2019
      • 216
      Hi there again.
      thnx for replying.
      Now I managed to create recovery disk for this process but when win+B then power whilst holding the keys only the fan and lights come on..
      I made a bootable freedos usb and booted into that with the bios file.
      But what command do i need..Pls check this photo and tell me what I need to do.
      Someone put pw on bios now I need to reset.
      • vikivng
        • Feb 2019
        • 216
        I get bad command or filename when I try to run the .bin file.
        New to this so some help would be great.
        I assume I am in the right directory.?
        I tried with and without quotes.
        Same error.
        Sorry for the vague first post lol..
        • vikivng
          • Feb 2019
          • 216
          anyone ???
          • gualancho
            • Jul 2020
            • 3
            • mexico
            good afternoon i have the same problem, thanks
            • vikivng
              • Feb 2019
              • 216
              Originally posted by gualancho
              buenas tardes tengo el mismo problema, gracias
              hI did you have success finding a solution?
                • 20709
                Same error.
                You can`t do it that way. Try the HP PC HARDWARE DIAGNOSTICS 4-IN-1 USB KEY instead.
                https://www8.hp.com/uk/en/campaigns/.../pc-diags.html
                http://ftp.hp.com/pub/softpaq/sp1040...0/sp104235.exe
                If that doesn`t work you`ll need an SPI bios programmer to backup your bios, then post it here and one of the members will try and fix it,or give you a working bios.
                • vikivng
                  • Feb 2019
                  • 216
                  Ok smdflea,
                  I did buy a programmer,just wanted to be sure to try all other methods before disassembly.
                  Ill try this..thnx
                  Do I need to create a boot disk with this method?
                    • 20709
                    You will need to make a USB key,just read the README file and click on the makekey.bat ,it will make the key for you .
                    • vikivng
                      • Feb 2019
                      • 216
                      I tried it..All this does is diagnose the hardware etc ?
                      I didnt see any reference to the bios. Is that right?
                      • studdy05
                        Bricked HP Probook 450 G7 Bios questions
                        by studdy05
                        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                        Ive got...
                        07-08-2025, 09:24 PM
                      • The_Memory_Guy
                        Dell T7820 stuck in Bios Recovery Mode
                        by The_Memory_Guy
                        HI,
                        I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                        What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                        All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                        https://www.dell.com/support/product...BUT090/drivers
                        Some...
                        07-07-2025, 06:52 AM
                      • jendkkd jeje
                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                        by jendkkd jeje
                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                        10-11-2024, 03:12 PM
                      • the_raz
                        Need (unlocked) bios for HP Probook 450 G3 Notebook
                        by the_raz
                        I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                        Laptop number 1:
                        Model: HP ProBook 450 G3
                        Motherboard part number:...
                        12-17-2024, 03:37 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
