a1502 2015
  • alihomee
    • Dec 2012
    • 1599
    • malaysia
    Re: a1502 2015
    can anyone help
      • 22293
      Re: a1502 2015
      Originally posted by alihomee
      can anyone help
      There`s nothing wrong with the bios posted by @peste ,your problem is somewhere else.
      • aqibi_
        820-4924-A MBPr 2015 running slow, possible ME Region?
        by aqibi_
        MBPr 2015 13" Early 2015 820-4924-A
        Running slow, with SMC bypass works fine:
        It has a NVME SSD Crucial P2 (1TB), tried another NVME adapter too.
        - No water indicators tripped
        - Sensors using iStat /HW show sensible values, only airport showing 129 degree (which is common) since we don't have ASD for this year board.
        I have removed and dumped the EFI/BIOS:
        - does cleaning the ME Region make sense?
        Side notes
        1) I do not have the original nor compatible SSD to test with
        2) battery is showing service...
        05-06-2023, 07:44 AM
      • iMuhtaseb
        A1502 2015 820-4924 no power
        by iMuhtaseb
        board came in cleaned up from a previous technician.. after examining the board visually I've seen some work done on the EFI/firmware..
        I've taken the chip out and it reads ok on Mac EFI Toolkit, I can read the SN and other information normally..
        I have taken a look into the board and I could not find anything suspecting.. I tried to look for corroded chips or corroded caps even to see if there's any areas damaged by liquid and I could not..
        I've taken some measurements:
        PPBUS 12.6
        PP5V_S5 present
        PP3v3_S5 present
        S4 rails when...
        06-29-2024, 05:29 AM
      • Destroyer-Br
        [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
        by Destroyer-Br
        I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
        When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
        If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
        After flashing it, the board does not power on — no signs of life.
        I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
        11-23-2025, 02:48 PM
      • duwane
        KB and Trackpad only work in safe mode - 820-4924-A Macbook Pro Late 2015 A1502
        by duwane
        Hi all. I hope someone has come across something similar, as I am baffled.
        I have a faulty logic board from a 2015 A1502 Macbook Pro Retina (820-4924-A). Some signs of liquid, but all corrosion cleaned, and several components refloated or replaced to eliminate any visually corroded areas of the board.
        Machine boots fine now, but the keyboard and trackpad do not work at all when booting normally into Catalina, Big Sur, or Monterey. At the login screen, the cursor does not move at all when moving on the trackpad, and no keys on the keyboard respond on screen, however...
        04-11-2022, 08:49 PM
      • tom3k
        Dell Precision 5540. Need clean ME Region
        by tom3k
        Laptop: Dell Precision 5540
        MB: LA-H331P Rev: 1.0(A00)
        Hi.
        I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
        After extracting my BIOS in FIT the ME Region size is 7565 KB.
        However the ME Region files I fouud online are 11688 KB in size.
        Can someone help me find he correct clean ME Region?
        Thanks!
        Code:
        ║ Family │ CSE ME ║
        06-28-2025, 12:34 PM
