a1502 2015
  • alihomee
    • Dec 2012
    • 1598
    • malaysia
    a1502 2015
    looking for a clr me region file this model.....mobo code is 820-4924-a
  • alihomee
    • Dec 2012
    • 1598
    • malaysia
    Re: a1502 2015
    any one having the clean file.....
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      Re: a1502 2015
      Use search..
      https://www.badcaps.net/forum/showthread.php?t=53715 look on post #16
      • alihomee
        • Dec 2012
        • 1598
        • malaysia
        Re: a1502 2015
        tried with above file but its same for my notebook
        • alihomee
          • Dec 2012
          • 1598
          • malaysia
          Re: a1502 2015
          anybody have the file
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            Re: a1502 2015
            with this bios what problem laptop does?
            • alihomee
              • Dec 2012
              • 1598
              • malaysia
              Re: a1502 2015
              it goes so slow even cannot load os
              • peste
                • 13924
                • ROMANIA
                Re: a1502 2015
                do you still have the original bios?
                • Claudiomfa
                  • Nov 2015
                  • 455
                  • Portugal
                  Re: a1502 2015
                  The original bios do the same problem?
                  • alihomee
                    • Dec 2012
                    • 1598
                    • malaysia
                    Re: a1502 2015
                    so sorry i dont have ori file
                    • peste
                      • 13924
                      • ROMANIA
                      Re: a1502 2015
                      try
                      • alihomee
                        • Dec 2012
                        • 1598
                        • malaysia
                        Re: a1502 2015
                        tried with above file but still same ..here is some info regarding notebook/////////a1502 emc2835 serial:c02qvarzfvh3
                        • peste
                          • 13924
                          • ROMANIA
                          Re: a1502 2015
                          try..
                          • alihomee
                            • Dec 2012
                            • 1598
                            • malaysia
                            Re: a1502 2015
                            is it the same file as above
                            • peste
                              • 13924
                              • ROMANIA
                              Re: a1502 2015
                              it's not the same .. try ..
                              • alihomee
                                • Dec 2012
                                • 1598
                                • malaysia
                                Re: a1502 2015
                                tried but still same its very slow ...........btw thanks for ur effort
                                • alihomee
                                  • Dec 2012
                                  • 1598
                                  • malaysia
                                  Re: a1502 2015
                                  anybody can help
                                    • 22279
                                    Re: a1502 2015
                                    Do you know the serial number,and have you run apple ASD .
                                    • peste
                                      • 13924
                                      • ROMANIA
                                      Re: a1502 2015
                                      the bios from post#13 was edited with the serial from post#12 and clean me ..
                                      • alihomee
                                        • Dec 2012
                                        • 1598
                                        • malaysia
                                        Re: a1502 2015
                                        c02qvarzfvh3 .......this is ori serial found at the back of notebook
                                        • aqibi_
                                          820-4924-A MBPr 2015 running slow, possible ME Region?
                                          by aqibi_
                                          MBPr 2015 13" Early 2015 820-4924-A
                                          Running slow, with SMC bypass works fine:
                                          It has a NVME SSD Crucial P2 (1TB), tried another NVME adapter too.
                                          - No water indicators tripped
                                          - Sensors using iStat /HW show sensible values, only airport showing 129 degree (which is common) since we don't have ASD for this year board.
                                          I have removed and dumped the EFI/BIOS:
                                          - does cleaning the ME Region make sense?
                                          Side notes
                                          1) I do not have the original nor compatible SSD to test with
                                          2) battery is showing service...
                                          05-06-2023, 07:44 AM
                                        • iMuhtaseb
                                          A1502 2015 820-4924 no power
                                          by iMuhtaseb
                                          board came in cleaned up from a previous technician.. after examining the board visually I've seen some work done on the EFI/firmware..
                                          I've taken the chip out and it reads ok on Mac EFI Toolkit, I can read the SN and other information normally..
                                          I have taken a look into the board and I could not find anything suspecting.. I tried to look for corroded chips or corroded caps even to see if there's any areas damaged by liquid and I could not..
                                          I've taken some measurements:
                                          PPBUS 12.6
                                          PP5V_S5 present
                                          PP3v3_S5 present
                                          S4 rails when...
                                          06-29-2024, 05:29 AM
                                        • Destroyer-Br
                                          [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
                                          by Destroyer-Br
                                          I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
                                          When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
                                          If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
                                          After flashing it, the board does not power on — no signs of life.
                                          I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
                                          11-23-2025, 02:48 PM
                                        • duwane
                                          KB and Trackpad only work in safe mode - 820-4924-A Macbook Pro Late 2015 A1502
                                          by duwane
                                          Hi all. I hope someone has come across something similar, as I am baffled.
                                          I have a faulty logic board from a 2015 A1502 Macbook Pro Retina (820-4924-A). Some signs of liquid, but all corrosion cleaned, and several components refloated or replaced to eliminate any visually corroded areas of the board.
                                          Machine boots fine now, but the keyboard and trackpad do not work at all when booting normally into Catalina, Big Sur, or Monterey. At the login screen, the cursor does not move at all when moving on the trackpad, and no keys on the keyboard respond on screen, however...
                                          04-11-2022, 08:49 PM
                                        • tom3k
                                          Dell Precision 5540. Need clean ME Region
                                          by tom3k
                                          Laptop: Dell Precision 5540
                                          MB: LA-H331P Rev: 1.0(A00)
                                          Hi.
                                          I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
                                          After extracting my BIOS in FIT the ME Region size is 7565 KB.
                                          However the ME Region files I fouud online are 11688 KB in size.
                                          Can someone help me find he correct clean ME Region?
                                          Thanks!
                                          Code:
                                          ║ Family │ CSE ME ║
                                          06-28-2025, 12:34 PM
