HP Elitepad 900 BIOS
  • Ksama
    • Jun 2020
    • 3
    • France
    Is it possible to remove password from my HP Elitepad 900 BIOS dump please?
    Chip Winbond 25X40CLSIG.
    Thank you!
    Best regards!
  • Mazorca
    • Jan 2017
    • 463
    Re: HP Elitepad 900 BIOS
    try this one and report result.
      • 21914
      Thank you!
      Best regards!
      It isn`t the full bios only part of it. The other part is probably in the eMMC, you need an eMMC reader/programmer.
      • Ksama
        • Jun 2020
        • 3
        • France
        It's working thank you!
          • 21914
          its strange, theres not much difference between the two files .
          • Mazorca
            • Jan 2017
            • 463
            SMDFlea, Hp unlocker was used, I did not mess with the ME region, I am surprised and happy it worked too.
            • mxtestview
              • Sep 2018
              • Poland
              Password is stilo on.
              • boingboing
                • May 2016
                • 4
                • England
                Working bios in english with no bios password
                • Jmariano
                  • Nov 2020
                  hello friend i would like some help to locate the IC to read the BIOS please...
                  • peste
                    • Dec 2016
                    • 13600
                    • ROMANIA
                    post clear pictures with the motherboard and someone will help you.
                    • Schakall
                      • May 2023
                      • Cameroon
                      Hello.
                      My HP ElitePad G1 not install any OS after bio setting update.
                      I need your help
                        • 21914
                        Originally posted by Schakall
                        Hello.
                        I need your help
                        • Tomcat01
                          • Oct 2023
                          • France
                          HP ElitePad 900 G1
                          Hi !
                          I try to remove the BIOS password on a HP ElitePad 900 G1 but the file patched by HPUnlocker don't delete it.
                          I also try to use RcUnlocker to patch my binary but the .exe constantly return me "mssing unlockable content" (i drag/drop the .bin file to .exe)
                          Serial number: CND34311TN
                          • volinakis
                            • Jan 2021
                            • 2874
                            • N/A
                            Re: HP ElitePad 900 G1
                            Originally posted by Tomcat01
                            Hi !
                            try this.
                            • Tomcat01
                              • Oct 2023
                              • France
                              Originally posted by volinakis
                              try this.
                              work perfectly ! thank you !
                              I'm begginer with chip flashing and i'm curious to know how the procedure work
                              i checked my .bin source with yours with HexCmp and i notice a lot of changing in the data, what i did wrong ?
                              • volinakis
                                • Jan 2021
                                • 2874
                                • N/A
                                I took bios from post #8 which is reported as working with no password and put your DMI into it. only works this way in few old laptops, is not a general rule. if you want to learn more about bioses you should read BIOS guides, methods, resources and tools section.
                                https://www.badcaps.net/forum/showth...t=phoenix+bios
                                • KN89BG
                                  • Feb 2019
                                  • 3
                                  • Bulgaria
                                  HP Elitepad 900 68CUA F.03, error 501 Missing/Corupt BIOS-bios psw on it in other cases, could not upgrade flash in OS(psw-lock)..
                                  here is dump w25x40Bv..
                                  help to unlock/clean me, please.
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                • peste
                                  • Dec 2016
                                  • 13600
                                  • ROMANIA
                                  post S/N, full name and model, motherboard model, product number,etc.
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • TechMark1
                                    Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
                                    by TechMark1
                                    I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
                                    09-21-2025, 03:36 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
