lenovo IdeaPad S145 bios needed
  • cetincet
    • Jan 2014
    • 24
    • Turkey
    #181
    Re: lenovo IdeaPad S145 bios needed
    hello Lenovo ideapad s145-15 API bios is broken. Mainboard GS440&GS540 NMC511 Rev: 1.0 Ryzen7 cpu. There is no video card. The corrupted bios is attached, can you fix it? The bios files in the subject are tried, but it gives driver error and blue screen.
    • lapfix
      • Mar 2020
      • 2765
      • my workshop
      #182
      Your serial number
      • cetincet
        • Jan 2014
        • 24
        • Turkey
        #183
        Originally posted by lapfix
        Your serial number
        S/N PF1DTNTY
        MTM: 81UT003HTX
        thanks
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          #184
          That is the latest bios version from Lenovo, hope it works fine.
          all donations are welcome,
          • cetincet
            • Jan 2014
            • 24
            • Turkey
            #185
            thank you very much. It's working mate.
            • Yunusemre
              • Dec 2020
              • Türkiye
              #186
              Hello GS440 NMC5 REV 1.0 2019-05-28 There is a problem with the AMD system, I took a backup of the original bios, another bios then again after a while the device breaks down again reboot& GS440 is on again, then it is displayed again the bios comes again after a while & the GS540 comes back to the bios again and again What could be the reason for going after a while&GS540 device?
              sn : PF1ZKN9E MTN :81UT0089TX
              • palembang
                • Sep 2014
                • 15
                • indonesia
                #187
                can someone fix my bios dump,, problem is power led blinking and no display, thanks in advanced
                s/n PF1XRT8W
                MTM 81UVQ059ID
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12428
                  #188
                  s/n PF1XRT8W
                  MTM 81UVQ059ID
                  S145-14API Laptop (ideapad) - Type 81UV
                  ​https://www.badcaps.net/donate
                  • palembang
                    • Sep 2014
                    • 15
                    • indonesia
                    #189
                    Thank you, i'll try now mate.
                    • palembang
                      • Sep 2014
                      • 15
                      • indonesia
                      #190
                      it still no change mate. blinking and no display.
                      • Yunusemre
                        • Dec 2020
                        • Türkiye
                        #191
                        help ? It is not in a position to fix the bios, my problem is not displayed, the trap comes late when the control is disabled.
                        SN: PF1ZKN9E MTN :81UT0089TX
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12428
                          #192
                          You have hardware problem.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12428
                            #193
                            S145-15API Laptop (ideapad) - Type 81UT
                            • palembang
                              • Sep 2014
                              • 15
                              • indonesia
                              #194
                              yes mate, it's about hardware faulty, i already cheked after flashing with replace dmi but no change. now faulty have been solved.
                              thank you for respon mate.
                              • tahahey
                                • 15
                                • Turkey
                                #195
                                Hello, i need bios for this GS440&GS540 NMC511 s145-15API 81UT i tried the one posted above it's not working. Attached is the original bios
                                • hardware1
                                  • Sep 2021
                                  • 2949
                                  • N/A
                                  #196
                                  Did you tried the file from post #184?
                                  • tahahey
                                    • 15
                                    • Turkey
                                    #197
                                    yes but not display
                                    • hardware1
                                      • Sep 2021
                                      • 2949
                                      • N/A
                                      #198
                                      yes but not display
                                      It's the latest version from lenovo without editing, so maybe you have another problem.
                                      • Valeriusto1999
                                        • Nov 2022
                                        • italia
                                        #199
                                        Originally posted by SMDFlea
                                        Here you go rich ,bios + EC .
                                        NM-C121 KB_pins=32 LEFT DOWN 08MM PD0=13 PD1=17 PD2=19 PD3=24 PD4=20 PD5=16 PD6=23 PD7=21 BUSY=10 STB=18 AFD=7 INIT=14 SLIN=15 KSI4=11 KSI5=12 IT8586E
                                        hello, I have a lenovo S145-15IWL, with black screen, I tried your vl bios, the fan runs with led on (not flashing) but I don't see anything, do you have a solution?
                                        Thanks in advance
                                        • joaconet
                                          • Nov 2022
                                          • Argentina
                                          #200
                                          Good morning, I have a problem with the Lenovo S145-14API with the AMD 3020e CPU.
                                          Serial number PF38R8Q6.
                                          Bios Winbond 25Q64FWSIQ.
                                          It happened that the automatic update appeared, when giving it update, it completed the installation correctly (it appeared on the screen), it restarted and it never gave an image again.
                                          It turns on the pc, but it doesn't do anything. I checked the components but nothing more.
                                          Thank you in advance for any possible help.
                                          • joven016
                                            Lenovo Ideapad S145 need working bios HELP!!
                                            by joven016
                                            Problem is blinking power led only
                                            i don't know exactly if it's s145-15igm or s145-14igm
                                            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                            Already tested some of posted bios here
                                            S145-14igm - success but invalid serial and not booting on OS
                                            S145-15igm - success with serial and some other info in bios but still not booting on OS
                                            already tried installing new windows but always booting on bios setup
                                            windows installer flash drive detected on...
                                            08-21-2025, 10:55 PM
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
                                          • mkdj
                                            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                            by mkdj
                                            Dear all,
                                            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                            Here the steps I have taken to fix the laptop:
                                            - downloaded latest BIOS from Lenovo Website...
                                            10-18-2025, 03:43 AM
                                            Lenovo IdeaPad S145 Notebook S Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...
                                            09-06-2024, 04:40 PM
                                            09-06-2024, 04:00 PM
