AAL15 LAD071P Rev. 1.0 (A00)
  • SKOER
    • May 2020
    • México
    could someone help me with the mother dell bin AAL15 LAD071P Rev. 1.0 (A00)
  • peste
    • 13451
    • ROMANIA
    Re: AAL15 LAD071P Rev. 1.0 (A00)
    try
    https://www.laboneinside.com/tag/aal...-1-0-bios-bin/
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
