15-ay032nx la-d703p
  • saqersaleh
    • May 2017
    • 14
    • jordan
    15-ay032nx la-d703p
    hp 15-ay032nx la-d703p rev 3.0 bios dump pls hlp...
  • sourcebf
    • Jul 2016
    • 431
    • N/A
    Re: hp 15 bios
    One of those is your Bios from HP web site......backup and try...
    • saqersaleh
      • May 2017
      • 14
      • jordan
      Re: hp 15 bios
      tnx sir its work this
      081EF
      bord id :- la_d703p rev3.0
      • chadı
        • Mar 2016
        • 5
        • turkey
        Re: hp 15 bios
        hello
        do you have kbc 128k for la-d703p v3.0
        • Vacia
          • Sep 2015
          • Ukraine
          Re: hp 15 bios
          HP 250 G5 (bdl50 la-d703p rev 3.0) dump bios.
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • MDSI
            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
            by MDSI
            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
            Details:
            Model : HP OMEN 17-an012nf
            Motherboard Part Number : DAG3BAMBAF0 REV : F
            Serial Number (S/N) : 5CD7280D51
            BIOS chip : Winbond W25Q64VSIQ
            Programmer : EZP2023+
            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
            I already...
            Yesterday, 07:11 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
