HP Elite X2 bios
  • JPToadstool
    • May 2020
    • 19
    • United Kingdom
    HP Elite X2 bios
    Looking for a clean BIOS file to flash to a HP Elite X2 1012 g2. Please let me know if more info is needed. Many thanks!
  • lapfix
    • Mar 2020
    • 2756
    • my workshop
    Re: HP Elite X2 bios
    You want to clean or to unlock !
    HP elite wrong size!
    • JPToadstool
      • May 2020
      • 19
      • United Kingdom
      Sorry, I'm new here. What's the difference between clean vs unlock?
      The size of the HP Elite is what was given by flashrom - what could be wrong?
      • lapfix
        • Mar 2020
        • 2756
        • my workshop
        Unlock = there is password on your bios that you want to delete it ..clear it.
        Clean = The SPI/BIOS chip firmware is divided into regions (3-4), one of them must be clean it .
          • 21672
          The bios chip you need to backup is W25Q128FV ,its a 16MB bios.
          • JPToadstool
            • May 2020
            • 19
            • United Kingdom
            I do not see that chip on the board. I do however have a 25Q128JVPQ - could it be this chip instead?
            • lapfix
              • Mar 2020
              • 2756
              • my workshop
              yes that's it
              • JPToadstool
                • May 2020
                • 19
                • United Kingdom
                Originally posted by lapfix
                yes that's it
                Here should be the correct one. Thank you
                • peste
                  • Dec 2016
                  • 13421
                  • ROMANIA
                  try..
                  • JPToadstool
                    • May 2020
                    • 19
                    • United Kingdom
                    Originally posted by peste
                    try..
                    Thanks, need to replace the USB-C port as it isn't charging, but will let you know if it works later.
                    • Wheldon93
                      • Apr 2020
                      • United Kingdom
                      hey what software are you using to program this, i am having issues with detecting the chip.
                      • JPToadstool
                        • May 2020
                        • 19
                        • United Kingdom
                        I've been using flashrom as part of Mac. You need home-brew installed if you're running Mac and then installing with "brew install flashrom". Other Linux / Unix distros you can use "apt-get install flashrom"
                        • chkintl93
                          • Jun 2019
                          • 47
                          • usa
                          try..
                          Just checking. Is the bios file posted a clean ME and unlocked file or is it just an unlocked bios file? Just wanted to check before moving forward. Thank you so much for the the help.
                          • peste
                            • Dec 2016
                            • 13421
                            • ROMANIA
                            is a file that merged the original bios from post # 8, the update on the site and cleaned the ME region, if you want to use it, make a copy of the bios of your laptop beforehand and check that it is correct ...
                            • chkintl93
                              • Jun 2019
                              • 47
                              • usa
                              Thanks a lot for the quick detailed reply. I got a couple of questions as follows.
                              (1) Is your file also unlocked, no bios password?
                              (2) Is it possible you can provide links in the forum or other websites showing how to unlock hp bios password and how to make clean ME files?
                              Appreciate your help.
                              • peste
                                • Dec 2016
                                • 13421
                                • ROMANIA
                                Yes ... he doesn't have a password ..
                                don't forget to make a copy of the original bios of the laptop, and check it with the HxD program, before writing the bios chip
                                https://www.badcaps.net/forum/showthread.php?t=88533
                                https://www.badcaps.net/forum/showthread.php?t=79956
                                • chkintl93
                                  • Jun 2019
                                  • 47
                                  • usa
                                  Thank you so much for the reply. Noe I got a better idea of the situation. And I'll go ahead to work on it. This is a wonderful forum. You have been a great help. Really appreciate all your efforts.
                                  • ictc
                                    • May 2015
                                    • 46
                                    • Italy
                                    Can anybody remove the password from this dump please?
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      Read the rules before posting:
                                      BIOS guides, methods, resources and tools
                                      Password removal by laptop brand
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                      • ictc
                                        • May 2015
                                        • 46
                                        • Italy
                                        Thanks to you, I learned how to use the proper tool and get the password removed. Can you please cancel my other post ?
                                          HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + Elite Presenter Mouse + Essential Top Load Case boardview and 1012 G2 + Elite Presenter Mouse + Essential Top Load Case schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-06-2024, 08:20 AM
                                          HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 07:10 AM
                                          HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet boardview and Elite x2 1012 G2 Tablet schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 06:30 AM
                                          09-06-2024, 06:10 AM
