Panasonic CF-31 BIOS Dump
  • rp.labs
    • Apr 2020
    • NoWhere
    Can someone help me with a BIOS dump made with a programmer for a CF-31 Mk5? My BIOS version is customized and it seems it is missing some menus, startup logo and messages. Since it is a custom BIOS the Panasonic BIOS update program doesn't want to update it either.
    Thanks and Best regards!
    • 21932
    Re: Panasonic CF-31 BIOS Dump
    Post your bios backup.
    • rp.labs
      • Apr 2020
      • NoWhere
      To explain a little bit what is happening and what things I noticed in this custom BIOS:
      1) No BIOS Logo or Text "Press F2 for..."
      2) No Password setup in the Security Menu.
      3) BIOS had User and Admin Password. The attached one has them removed. it works fine.
      4) When you select Load Defaults it's adding back the BIOS password. I needed to reflash again so I can go back to BIOS
      5) Version number is V5.00L10 Mxx. If it has an M in the version is custom and the BIOS update tool will not update it.
      Maybe removing the Mxx string from BIOS version can trick the BIOS update tool to continue the upgrade.
      I attached my BIOS and the BIOS AMI Capsule from the update package.
      • Latechs-JOJO
        • Feb 2022
        can you send me some links how to update my BIOS please Thanks and Software .. I have the EZP2010 I use to read but I don't know where the BIOS is located. Newbie here
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
