I need a working bios and EC on this model, attached is the backup main bios please i need working bios and ec
Acer E5-475G bios and EC need
Tags: None
Re: Acer E5-475G bios and EC need
Use the search, theres a few bios already posted.Just copy your DMI + win key from old bios to the new one.Or try cleaning the ME region of your dump.Comment
@smdflea I already tried posted here not working for this because different board id here is my board id DAZ8VMB18D0 REV DComment
try this one..made from your bios and update from the Acer site.Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Post your original bios backup.
https://www.badcaps.net/forum/showthread.php?t=88533----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Try the bios again at post #7 ,its been replaced with a clean ME version. Or post your original backup if you want your original DMI,serial,win key adding .Comment
Re: ME Firmware Cleaning Guide
here is my bios Acer E5-475G DAZ8VMB18D0 X32
I need your help to clean ME Region
Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
done. Thank you so much!Post your original bios backup.
https://www.badcaps.net/forum/showthread.php?t=88533Comment
Sure, no worries.
We are not playing games here, this is not your original bios. I've asked for your original dump and bolded in purpose this word.
You just waste my time. I won't bother anymore with this matter.----------------------------------------------------------------------------------------------------------------------------------------------------------
plese help build my bios
With power no display
DAZ8VMB18D0 REV D, Z8V X32Attached Filesif you find these attachements useful please consider making a small donation to the site
Type and post the laptop serial number, read the rules https://www.badcaps.net/forum/troubl...before-posting
SNID: 726049466076Attached Filesif you find these attachements useful please consider making a small donation to the site
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
by Wg188I have an Acer veriton Z4660G all in one pc,
Model: Z4660G-I5850H1 (VZ4660G_W)
Need bios dump and schematic would save my life !
to make a long story short I bought this all in one used
with a broken lcd, with the objective of making a custom desktop out of it
,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...-
by ub6ib969Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
Model Number: PO3-650
Part Number: DG.BK4AA.006
Serial Number : 33400117730
BIOS IC : XM25QH256C
I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...-
by zarabotaHello,
I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...-
by verniumENMy laptop model is EX215-23-R7NG
BIOS chip XM25QU128C
Here is my original bin file, as well as how the BIOS chip looks like
My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...-
- Loading...
