hp 15-bs031ne BIOS
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    hp 15-bs031ne BIOS
    Hi
    hp 15-bs031ne when power on, a white screen is appering with no data
    i tried to boot from hdmi, with no success
    when i press keys , i can heard beep....
    i tried to update bios with recovery method, but i get 2 fast caps lock and 2 slow, with no screen
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: hp 15-bs031ne
    it seems that your bios is corrupted now ! post your old one .
    after we see if white screen still or not
      • 22276
      Re: hp 15-bs031ne
      Bios requests https://www.badcaps.net/forum/forumdisplay.php?f=40
      • mazloum
        • Sep 2012
        • 504
        • Lebanon
        Re: hp 15-bs031ne
        this is my bios:
        • mazloum
          • Sep 2012
          • 504
          • Lebanon
          Re: hp 15-bs031ne
          i flashed it with this, but still the same:
          https://www.badcaps.net/forum/showth...light=la-e791p
            • 22276
            Re: hp 15-bs031ne
            Didn`t you read post #3 .Never mind, i`ll move this thread to the "Bios Requests" section.
            • mazloum
              • Sep 2012
              • 504
              • Lebanon
              Re: hp 15-bs031ne BIOS
              but i thought it is not bios problem
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                as smdflea said...post your bios in appropriate section please
                • mazloum
                  • Sep 2012
                  • 504
                  • Lebanon
                  i already post it
                  • lapfix
                    • Mar 2020
                    • 2764
                    • my workshop
                    try this and give feedback
                    • mazloum
                      • Sep 2012
                      • 504
                      • Lebanon
                      it still the same problem, white screen as soon as i press power button, with no display,
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        and 2 fast caps lock and 2 slow are dissapear !
                          • 22276
                          Try this bios at post #4 https://www.badcaps.net/forum/showthread.php?t=71282
                          • mazloum
                            • Sep 2012
                            • 504
                            • Lebanon
                            [QUOTE=lapfix;953675]and 2 fast caps lock and 2 slow are dissapear ![/
                            the caps was blinking only when i try to recover bios by usb method, but now when i power it on it will shutdown after 2 seconds, still white screen, i noticed that the white screen is present even when i remove ram
                            • lapfix
                              • Mar 2020
                              • 2764
                              • my workshop
                              try the bios at post 13 ( Same BID) , if not make sure your problem NOT on LVDS cable or LED panel.
                              • mazloum
                                • Sep 2012
                                • 504
                                • Lebanon
                                now i got a new problem beside the white screen, the laptop will shut down after 2-3 seconds, no fan spin, i cleaned ram now fan ok and doesnot shutdown, but it keeps restart every 19-20 seconds,, i changed led panel, but the cable i have no one to change
                                • mazloum
                                  • Sep 2012
                                  • 504
                                  • Lebanon
                                  by the way the board: csl50/csl52 la-e791p rev: 2.0
                                  • lapfix
                                    • Mar 2020
                                    • 2764
                                    • my workshop
                                    Did you try the bios post 13 !!
                                    try this too : https://www.alisaler.com/hp-15-bs526...08328-bios-ec/
                                    • mazloum
                                      • Sep 2012
                                      • 504
                                      • Lebanon
                                      yes i tried....
                                      how can i flash ec??
                                      thanks
                                        • 22276
                                        Originally posted by mazloum
                                        yes i tried....
                                        thanks
                                        With a Vertyanov jig ,SVOD3,RT809H .What programmer(s) do you have ?
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • mitchw
                                          HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                                          by mitchw
                                          Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                                          After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                                          After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                                          I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                                          04-29-2025, 03:45 PM
                                        • BlueNitesFire
                                          I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                                          by BlueNitesFire
                                          So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                                          03-08-2025, 03:49 PM
                                        • Technodoc
                                          ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                                          by Technodoc
                                          Asus laptop G614JZ-N3012W Rog Strix with i7
                                          Mainboard G634J-PMV-VGT
                                          6050A3441302-MB-A01
                                          2023-02-10
                                          Power button works okay....power light goes on
                                          Red "bottom" leds go on
                                          Charging led works
                                          Fans do not spin, capslock key does nothing, screen stays black
                                          I would like to program the bios again, to rule out a corrupted bios.
                                          However I run into a size error
                                          The bios chip is a Winbond 25R256JVEN
                                          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                                          02-24-2025, 04:46 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
