Computrace on older Lenovos
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    What is the best way to remove computrace on older lenovos like T410, T420, T430, X220 etc?
    I guess rewriting L08 but if so, what part of it needs modifying?
  • Mario
    • Sep 2007
    • 64
    Re: Computrace on older Lenovos
    Coreboot ?
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Sure but not an option for me.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1375
        • France
        Did you find a solution?
        I unintentionally activated the computrace by doing tests.
        No computrace originally on it.
        I put back the files of the 2 Bios chips and also of the RF08
        but nothing changes. Still blocked.
        The funniest thing is that I tried to answer this post to find a solution ^^
          • 22293
          Did you try it with a formatted drive,it can live on a hard drive.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1375
            • France
            no disc, no device .just Motherboard for test.
            I haven't lost everything, I understood the password checksum
              • 22293
              So it can only be in the PCH ,intel PTT /intel anti-theft ?
              • Knucklegrumble
                • Jun 2020
                • 78
                • US
                Excuse my ignorance, but can't computrace be disabled permanently in bios settings?
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1375
                  • France
                  ENE KB9012QF
                  hey yes, I don't think there is a choice
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1375
                    • France
                    no it's grayed out now and message at startup. I didn't have message before touching the 24ps08 (enable "not activate")
                    put back as original it changes nothing (25q32 & 25q64 + ps08)
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1375
                      • France
                      In order :
                      I was in "enable (not activate)"
                      I have set to disable (I have saved)
                      then I put in "disabled permanently"(the window has become grayed out in "disabled" no more modification possible, it's normal.)save also
                      I inject reading of original ,think to find enable (not activate)
                      and from there I have the message: this pc is protected by absolute every time I want to enter the bios.
                      I then inject original of 2x 25Qxx +ps08 and always the message in red after F1
                        • 22293
                        Can you post the bios .
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1375
                          • France
                          here bios yoga 12 Model :20C0 ZIPS1 LA-A341P
                          edit :
                          there is not a Solution for SVP Password for these models? see photo 3
                          it's almost the same motherboard but not same
                          ZIPS3 LA-A342P
                          No MEC16
                          No 24PS08
                          just 25Q32 and 64 and ENE 9012QF
                          @Knucklegrumble your patch does not work on it
                          edit n°2:
                          even without the 24ps08, the bios see always computrace. he does not see serial number etc .. But it's normal.
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1375
                            • France
                            it's good, it works.
                            After starting without the 24Ps08, I put the last version permanently disabled.
                            And the Computrace message disappeared.
                            With option in the Bios "enable" but not Activate
                              • 22293
                              You can permanently disable it in FIT settings when cleaning the ME firmware
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1375
                                • France
                                Ha ok,
                                I'm a little lost with IntelMe
                                I go read it at Winraid to understand tools and everything that goes with them.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1375
                                  • France
                                  What is your tool? I don't know that?
                                  I modify and compare each byte to find the functions! you are cheating
                                  • jonyhdtv
                                    Lenovo T420 LNVH-41-AB570 how to deactivation Computrace
                                    by jonyhdtv
                                    please help me how to deactivate in BIOS Computrace
                                    BIOS is without password
                                    TYP: 4236-S76
                                    SN: PB-RMR60
                                    I don't know what method to use for this model. Info from Lenovo Autopatcher is bello:
                                    autopatch: error: unrecognized arguments: C:\BIOS\BIOS Read\Lenovo T420\W25Q64CV@WSON8.BIN
                                    Press any key to continue . . .​...
                                    02-07-2025, 02:32 AM
                                    Lenovo ThinkPad X220 X Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad X220 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X220 boardview and X220 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad X220 is...
                                    09-06-2024, 05:27 AM
                                  • Stunt
                                    Lenovo Thinkbook 16 G8 Computrace
                                    by Stunt
                                    Hi guys i've got Lenovo Thinkbook 16 G8 with computrace enabled only. Please note there is no bios password set on the laptop.
                                    The problem is computrace which's enabled and grayed out. Please if anyone who can help me i will appreciate it. Thank you
                                    Device: Laptop
                                    Brand: Lenovo
                                    Model: ThinkBook 16 G8
                                    Board number: 233068-5
                                    SN: PW0JCMEY
                                    Request: Remove computrace
                                    10-16-2025, 02:25 AM
                                  • kaput
                                    Lenovo Thinkcentre M720q, disable activated Computrace
                                    by kaput
                                    Not a BIOS request per se, but closely related. Please bear with me
                                    A while ago I found an old Lenovo Thinkcentre M720q in pieces in the electronics scrap bin at work. There was only some minor damage to the case, so collected everything and brought it home to let it dry and see if it still worked. It did
                                    Unfortunately Computrace has been activated on it. Since I'm using it as an emulation console with Lakka now, it's no big deal, but would be nice to get rid of the annoying message popping up when entering the UEFI setup, and also learn something along the way....
                                    06-28-2024, 09:36 AM
                                  • acedogblast
                                    Soldered wifi upgrade to wifi 7 BE200D2W from older AX2xx based moduels.
                                    by acedogblast
                                    I have finally found a source for Intel's BE200 wifi soldered "1216" sized modules (not the larger 2230 removable M.2 modules) and I was wondering if it is possible to swap the older AX2xxD2W wifi 6/6e with this new wifi 7 module on a laptop. Supposedly both the BE200D2W and the older AX2xxD2W chips use the standard "M.2 1216 footprint" but with an additional inner-ring of pads. We have schematics of various laptops that use the AX2xxD2W chips on this forum. What we need is a schematic of a laptop that uses the new BE200D2W to check if the pinout is identical or not. Do anyone...
                                    11-16-2024, 10:19 PM
