Haiii . anyone have la-9331p rev 1.0 bios bin file UH14 and U2
Re: la-9331p rev 1.0 bios bin file UH14 and U2
Hi
i have single beep and no display, i am uploading my bios....
can someone fix my bios
thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Only 1 single beeb !
https://www.dell.com/support/manuals...437&lang=fr-frComment
Every donation made will go towards server fees and maintenance costs.Comment
bios extracted from the Dell site update
DMI 6C7ED0-6C804FAttached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
maybe this can help its from i fixed laptop motherboard dell alienware LA-9331P REV 1.0 i just backup original bios and ec.Attached Filesif you find these attachements useful please consider making a small donation to the site
This is my apport people, thanks for the support, one is the BIOS UH4 and the EC U2 Backup from my Laptop and the other one are the BIOS and EC but with the region ME Clear, like a stock laptop (new)
i recomend to use the Region ME clear, in order to have the best result for the system
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
