gigabyte GA-RP55W5 Rev1.1 EC dump!
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hey guys, does anyone has known good BIOS + EC (ITE8587E) dump for this gigabyte laptop please?
    Laptop: Gigabyte P55
    Motherboard: gigabyte GA-RP55W5 Rev1.1
    Thank you in anticipation.
    • 21685
    Re: gigabyte GA-RP55W5 Rev1.1 EC dump!
    https://www.gigabyte.com/Laptop/P55W...upport-dl-bios
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Hi SMDFlea, I need the bin files. Is it as simple as extracting it from the zip file? I read that this method requires post editing of the hex (I am not sure). Or to use a BIOS extractor software (which I do not have).
      Can you please confirm? I don't have the schematic of this motherboard, So all programming is done offline and then soldered to the board. (Board has a shorted EC, so I have no idea what the actual size of the EC bin should be). I would like to avoid desoldering, reprogramming and resoldering.
      Please find attached BIOS and EC file as extracted from exe file.
        • 21685
        Can you post your bios and EC backups here .
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          Find attached BIOS backup. No EC backup since EC is shorted. I dumped the replacement EC chip and its file size is 128KB compared to 64KB of the extracted firmware.
            • 21685
            Bios + EC .Your win key included with both bios. W - 240000h
            B0D version is Non-Raid , D0D is Raid. I posted both as i`m not sure which version your dump is.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              EC works great and laptop boots but I don't have any image. Tried both BIOS + original dump. No luck. HDD spins up but no activity observed on LED. Please advise.
              Thank you for the files!
                • 21685
                Sorry the EC i posted was the extracted one padded out to 128KB, its not the full EC,just an update. Here is the full EC extracted from the bios
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  Still the same unfortunately. Laptop boots but no display and no HDD activity. If I press and hold power button to force it off, it restarts on its own once it turns off.
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    Any idea/advise please?
                      • 21685
                      start a new thread in the laptop forum, i don`t think its a bios or EC issue. Measure voltage on all large grey coils and check DC in and batt mosfets,post your results in the new thread.
                      • Spider1211
                        • Oct 2019
                        • 532
                        • Mauritius
                        All voltage rails, DC in are present and no faulty mosfets identified. When powered on, the screen can be seen going darker and goes back to a lighter color when power is removed.
                        I shall create a new thread with more details as advised nonetheless.
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          @SMDFlea; Just as an update, the EC you provided works great! I managed to get the laptop back up and running with just one last issue yet to be resolved (post coming up soon). Thank you!
                          • limpidity
                            • Sep 2019
                            • 49
                            Does Bluetooth work well?
