Need bios dump for Gigabyte Q77M-D2H rev 1.0
  • TiagoKaeshi
    • Aug 2016
    • 8
    • Brazil
    If anybody can help... I lost the original dump and can't find another one anywhere. Tryed the files from Gigabyte website but the onboard LAN and TPM won't work with them (had this issue in the past and only solved with a dump from a working motherboard)
  • dacount
    dacount
    • Sep 2024
    • Österreich
    I have this board in a non starting condition. Are you interested in this anymore? Cause I could try to read it out with the clamps of my CH341. Btw. the MAC adress is coded in an not accessibel part of the bios as I understand, may be wrong
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
