HP 15 BS102NT Bios need
  • naciakpinar
    • Aug 2019
    • 9
    • TÜRKİYE
    When the device starts, the screen is illuminated but there is no image. I tried another bios capslock 2 gives long 2 short light error. I couldn't find new bios. I would appreciate if you help. The backup is attached.
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: HP 15 BS102NT Bios need
    number board?
    • peste
      • 13619
      • ROMANIA
      try...
      • naciakpinar
        • Aug 2019
        • 9
        • TÜRKİYE
        I tried but it doesn't work. It looks like the image will appear on the screen, but it turns off and starts again. Capslock also does not indicate any errors. Thank you.
        Board DKL50 LA-E802P Rev : 1.0 2017-06-23
        • peste
          • 13619
          • ROMANIA
          try this..
          • naciakpinar
            • Aug 2019
            • 9
            • TÜRKİYE
            unfortunately it didn't work but thanks for your help
            • Claudiomfa
              • Nov 2015
              • 455
              • Portugal
              try and report
              • naciakpinar
                • Aug 2019
                • 9
                • TÜRKİYE
                It did not work. I think there is another malfunction
                • Andrew_R
                  Banned
                  • Jun 2018
                  • 91
                  • Poland
                  Main BIOS + DMI + Win Key and EC file. If not work then you have hardware problem.
                  • ecnebi
                    • May 2023
                    • TR
                    Originally posted by peste
                    try this..
                    Originally posted by Claudiomfa
                    try and report
                    Hi peste, Hi Claudiomfa,
                    I need your support for bios file.
                    I installed the bios update from the official site (The relevant page on the HP official site is no longer available. It was live last week), the device did not turn on, black screen (old bios F.24).
                    I started with the desktop application, the system made a healthy update, but the device does not turn on.
                    I tried some bios files in this thread (with device CH341A).
                    What should I do ? Is there a special setting for the serial number/region? Should changes be made with the hex editor.
                    Board: DKL50 LA-E802P Rev 1.0
                    Model: HP15 BS102NT
                    • peste
                      • 13619
                      • ROMANIA
                      Model: HP15 BS102NT
                      post the original bios even if it is corrupted..
                      • ecnebi
                        • May 2023
                        • TR
                        Thank you for answer.
                        Unfortunately, I do not have the bios in the original device. There is a package installer (sp146927). I added the package contents. Published on the HP Site very recently.
                        • ecnebi
                          • May 2023
                          • TR
                          sp146927
                          F.72
                          2 MAY 2023
                          • ecnebi
                            • May 2023
                            • TR
                            I found the method that works, for those who are having trouble.
                            Use Ch341a V144
                            Power cable plug'in (not power on)
                            1- Erase Chip
                            2- Fill the buffer
                            3- Read
                            4- Write
                            5- Verify
                            I tried many times and it didn't work, I tried again today and the bios is (F.72) ok. Which of these files is the correct file?
                            084D4
                            0832D
                            0832E
                            08328
                            08445
                            I saw via cpu-z, The old bios F.24 motherboard model 823B - 23.40
                            I don't remember which new file I used, there are changes. F.72 823B - 23.77
                            Is the bios correct? (I think 8328)
                            • ay_erdi
                              • Feb 2013
                              • 74
                              • turkey
                              Use Ch341a V144
                              1- Erase Chip
                              2- Fill the buffer
                              3- Read
                              4- Write
                              5- Verify
                              084D4
                              0832D
                              0832E
                              08328
                              08445
                              Hi @ecnebi
                              I have similar problem.Can you share successfull bios.bin file ?
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • pirati
                              by pirati
                              10-27-2025, 04:20 PM
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
