When the device starts, the screen is illuminated but there is no image. I tried another bios capslock 2 gives long 2 short light error. I couldn't find new bios. I would appreciate if you help. The backup is attached.
HP 15 BS102NT Bios need
Tags: None
Every donation made will go towards server fees and maintenance costs.Comment
Re: HP 15 BS102NT Bios need
I tried but it doesn't work. It looks like the image will appear on the screen, but it turns off and starts again. Capslock also does not indicate any errors. Thank you.
Board DKL50 LA-E802P Rev : 1.0 2017-06-23Comment
try this..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
try and reportAttached FilesComment
Main BIOS + DMI + Win Key and EC file. If not work then you have hardware problem.Attached FilesComment
Hi peste, Hi Claudiomfa,
I need your support for bios file.
I installed the bios update from the official site (The relevant page on the HP official site is no longer available. It was live last week), the device did not turn on, black screen (old bios F.24).
I started with the desktop application, the system made a healthy update, but the device does not turn on.
I tried some bios files in this thread (with device CH341A).
What should I do ? Is there a special setting for the serial number/region? Should changes be made with the hex editor.
Board: DKL50 LA-E802P Rev 1.0
Model: HP15 BS102NTComment
Model: HP15 BS102NTDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thank you for answer.
Unfortunately, I do not have the bios in the original device. There is a package installer (sp146927). I added the package contents. Published on the HP Site very recently.Comment
sp146927
F.72
2 MAY 2023Comment
I found the method that works, for those who are having trouble.
Use Ch341a V144
Power cable plug'in (not power on)
1- Erase Chip
2- Fill the buffer
3- Read
4- Write
5- Verify
I tried many times and it didn't work, I tried again today and the bios is (F.72) ok. Which of these files is the correct file?
084D4
0832D
0832E
08328
08445
I saw via cpu-z, The old bios F.24 motherboard model 823B - 23.40
I don't remember which new file I used, there are changes. F.72 823B - 23.77
Is the bios correct? (I think 8328)Comment
Use Ch341a V144
1- Erase Chip
2- Fill the buffer
3- Read
4- Write
5- Verify
084D4
0832D
0832E
08328
08445
I have similar problem.Can you share successfull bios.bin file ?Comment
Read the rules before posting
by macabookHello everyone,
Channel: BIOS Requests ONLY!
Yesterday, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
