HP bios password unlocking
  • mr.Data
    • Sep 2018
    • 74
    • Netherlands
    I tried to unlock a HP EliteBook 820 G2. There were 2 chips on the motherboard so I tried both seperately with the HP unlocker:
    https://www.badcaps.net/forum/showth...=bios+unlocker
    After I did the first chip the password was still on the bios. After the second chip the laptop didn't work anymore.
    I have read something about an ec chip and that this chip is in sync with the bios.
    Do I need to desolder both chips and use the HP unlocker on both dumps before soldering them back on?
    Could someone please explain a bit about HP laptops with dual chips?
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: HP bios password unlocking
    So you did not read the whole topic.
    Larger chip contains main bios. For example if there are 25q128 and 25q64 chips, you only need to read and modify the 25q128 chip. Dont touch the smaller one.
    For now flash back both your original dumps and check if your laptop still works.
    • mr.Data
      • Sep 2018
      • 74
      • Netherlands
      Despite a lot of errors it worked with one of the ZBooks.
      I first tried with a EZP2019 but it read empty chip.
      Then I tried CH341a but gave errors (although it did work).
      Which programmer would you recommend?
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        I use two programmers but one is expensive and easy to use. The other one is cheap but difficult to setup/use.
        1. EasyJtag Plus
        2. Raspberry Pi + flashrom
        But did you do it like this:
        *Remove battery
        *Connect charger
        *Turn on laptop, click f1, f10 or whatever
        *Turn off laptop but DO NOT disconnect charger
        *Connect soic clip
        *Read and verify
        *Unlock
        *Write and verify
        *Disconnect charger and soic clip
        *Reconnect charger and Turn on laptop
        For some programmers this method works all the time. For other programmers there might be other methods.
        • mr.Data
          • Sep 2018
          • 74
          • Netherlands
          I have used the clip before with a couple of 6570b laptops which did work but I have tried about 10 different with clip but it took me too much time.
          Now I just remove BIOS battery, desolder chip and read it with EZP2019 OR CH341a if the EZP does not read it and then I solder it back on.
          • goop
            • May 2014
            • 45
            • state
            Why?
            *Connect soic clip
            Is the chip supposed to be powered even though the laptop's off?
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • baaligoga
              Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
              by baaligoga
              Good day, everyone!
              I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
              I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
              05-20-2023, 09:48 AM
            • traxformania
              TONGFANG "GM7TG7P" Bios Password Problem?
              by traxformania
              I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
              But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
              I'm trying to reset my bios without success.
              I tried :
              -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
              11-15-2023, 07:32 AM
            • tlindi
              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
              by tlindi
              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
              >Read BIOS guides, methods, resources and tools
              Ack
              >Try the method at BIOS guides, methods, resources and tools before requesting help
              Ack
              >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
              python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
              01-30-2025, 04:26 AM
            • Nopslide
              HP Omen 15-dh0052nf power-on & bios password
              by Nopslide
              Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
              My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
              Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
              04-01-2024, 04:27 PM
