need bios dump for hp spectre 13t 3000
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    hi everybody,
    i need bios dump for hp spectre 13t. motherboard: P/N:01018YB00-35K-G;
    THANK
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Re: need bios dump for hp spectre 13t 3000
    here is my old bios if can help fixed it
      • 22286
      Heres the full bios extracted from the HP bios update, plus your DMI .
      • alas3376
        • Nov 2011
        • 382
        • BENIN
        thank you SMDFlea, i will try and let you know
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          unfortunatly , didn't work for me but state change.
          maybe EC has problem. can you help me sending EC dump
          thank you very much
            • 22286
            Ec ,extracted from bios .
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              ok thank you for all, i'm going to try it
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Newer version of the bios - F.16 Rev.A
                It's also compatible with HP Spectre 13 Pro Notebook PC:
                https://support.hp.com/bg-en/drivers...R&ssfFlag=true for which the last available version at the support page is only F.14 Rev.A
                Become a Badcaps supporter
                Thanks to all supporters.
                • O.Szilard
                  • May 2019
                  • 163
                  • hungary
                  Thank you, this file gave life to a machine
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
