ThinkPad Thunderbolt 3 Firmware
    • 21936
    ThinkPad Thunderbolt 3 failure: What's happening, why it's happening, and how to fix it
    https://www.notebookcheck.net/ThinkP....451207.0.html
    https://nadim.computer/posts/2018-10-26-thinkpad.html
    https://pcsupport.lenovo.com/ca/en/solutions/ht508988
    ThinkPad Thunderbolt 3 Firmware attached,extracted from lenovo updates,plus links to driver downloads.Some models have 2 different firmwares, TBT.bin and AssistTBT.bin for the models that support or have bios assist enabled. NOTE: All the FW will need padding out with zeros using a hex editor to the size of the chip.
    EDIT: There is a Thunderbolt tool project on Github, try it and give feedback to the author please Whale linguini --> https://github.com/whalelinguni/LenovoThunderboltTool
    Systems may experience any of the following symptoms:
    USB-C port not working
    Intel Thunderbolt controller not visible in the OS/Device Manager
    USB-C or Thunderbolt docking stations not visible or having connectivity problems
    HDMI output not available
    System battery not charging with a USB-C power adapter connected to the USB-C port
    Intel Thunderbolt pop-up error message
    Intel Thunderbolt safe mode error message
    BIOS Thunderbolt communication error or hang during POST
    These symptoms may occur after 6 to 12 months of typical usage.
    These models are affected
    P43s (Type 20RH, 20RJ)
    P51 (Type 20MM, 20MN) P51 (Type 20HH, 20HJ)
    P51s (Type 20HB, 20HC) P51s (Type 20JY, 20K0)
    P52 (Type 20M9, 20MA) P52s (Type 20LB, 20LC)
    P53s (Type 20N6, 20N7)
    P71 (type 20HK, 20HL)
    T470 (Type 20HD, 20HE) T470 (Type 20JM, 20JN)
    T470s (type 20HF, 20HG) T470s (type 20JS, 20JT)
    T480 (Type 20L5, 20L6)
    T480s (type 20L7, 20L8)
    T490 (Type 20N2, 20N3) T490 (Type 20RY, 20RX)
    T490 (Type 20Q9, 20QH) T490s (Type 20NX, 20NY)
    T570 (Type 20H9,20HA) T570 (Type 20JW, 20JX)
    T580 (Type 20L9, 20LA)
    T590 (Type 20N4, 20N5)
    X1 Carbon 5th Gen - (Type 20HR, 20HQ)
    X1 Carbon 6th Gen - (Type 20KH, 20KG)
    X1 Carbon 7th Gen - (Type 20QD, 20QE) X1 Carbon 7th Gen - (Type 20R1, 20R2)
    X1 Yoga 2nd Gen (Type 20JD, 20JE, 20JF, 20JG)
    X1 Yoga 3rd Gen (Type 20LD, 20LE, 20LF, 20LG)
    X1 Yoga 4th Gen (Type 20QF, 20QG) X1 Yoga 4th Gen (Type 20SA, 20SB)
    X1 Tablet 3rd Gen (Type 20KJ, 20KK)
    X280 (Type 20KF, 20KE)
    X380 Yoga (Type 20NN, 20QN)
    X390 (Type 20Q0, 20Q1)
    X390 Yoga (Type 20LH, 20LJ)
    Yoga 370 (Type 20JJ, 20JH)
  • brontobyte
    • Jul 2021
    • 85
    • Romania
    Re: ThinkPad Thunderbolt 3 Firmware
    Hello. I have a Lenovo T480s Type 20L8. I run in some troubles with it. In slow charges and the thunderbolt is not working. When the charger is conected it does not work on 20V. When i open the laptop and the charger is plugged in the laptop complains about the charger. The battery slowly charges when the laptop is off. I can`t manage to put your firmware on my bios. Can you please help? Do you think is a hardware or a software issue?
    Thank you in advance!
      • 21936
      The thunderbolt firmware is flashed to a different chip,not to the bios chip. You should test with another charger first. If you want more help with it start a new thread in the main laptop forum - https://www.badcaps.net/forum/forumdisplay.php?f=23
      • brontobyte
        • Jul 2021
        • 85
        • Romania
        Thanks! I will open a new thread.
        • brontobyte
          • Jul 2021
          • 85
          • Romania
          Hello friend, i need your help.
          I have a faulty lenovo thinkpad T480, usb type C not Working.
          i need 1 MB File to write on the firmware chip
          i attached the original file
          Please, can you help me? THANKS!
          • hoaca388
            Badcaps
            • Jan 2022
            • 12333
            • brontobyte
              • Jul 2021
              • 85
              • Romania
              not working, i think is not the right file...
              • Dimuth Rubesinghe
                • Aug 2022
                • 7
                Hi i messed up my 25Q80 thunderbolt eeprom by thinking its the bios chip.
                I did make a back up of the original ( attached)
                but even when I flashed it back I still get the power adaptor not enough warning, so I think it didnt fix the issue.
                thinkpad x390 8th gen
                appreciate any assistance to get it back
                thanks
                  • 21936
                  thanks
                  https://www.badcaps.net/forum/showpo...70&postcount=3
                  • linxz
                    • Dec 2016
                    • 24
                    Hi Master,
                    Please help me,I have Lenovo thinkpad T480s. use full charged battery can wotking but power LED NOT On.when connect to power adapter
                    As PF2 has only 5V.No charging.They should bring it up to 20V. I try the docking port, PF1 5V. Check port no problem.I guess may be is U12 problem. firmwares problem.Pleaes tell how to flashe both TBT.bin and AssistTBT.bin to chip?thanks.
                    • brontobyte
                      • Jul 2021
                      • 85
                      • Romania
                      I have some issues with this model.
                      Lenovo Thinkpad x13 Gen1 Type 20ug sn:PC-28QECQW
                      The type c connector is not getting 20v, only 5v
                      The second one is working fine.
                      It's a firmware issue? Can someone help with the bin file?
                      • digitalpc
                        • Jun 2016
                        • 305
                        • .DLL
                        Anyone have file for Lenovo T15p
                          • 21936
                          Are you asking for T15p thunderbolt firmware ? .You havn`t provided enough info,can`t help without the laptop serial or model type.
                          • digitalpc
                            • Jun 2016
                            • 305
                            • .DLL
                            Yes i upload bin file, it charging with USB Pin and USB C just when is shut down
                            T15p Gen 1 (type 20TN 20TM)
                              • 21936
                              FW from the support page https://pcsupport.lenovo.com/us/en/p...%20Thunderbolt
                              Extracted with innoextract. 424KB FW padded out to 1MB using HxD.
                              If it doesn`t work try flashing the 1MB zero`s file at post #1 and -> https://www.badcaps.net/forum/showpo...70&postcount=3
                              • digitalpc
                                • Jun 2016
                                • 305
                                • .DLL
                                Same problem with both
                                  • 21936
                                  Maybe a problem with the charger,hardware or EC.Don`t know.
                                  • gsoft
                                    • Jul 2023
                                    • 38
                                    • Italy
                                    Hi, I have a T480 not charging batteries, I try another charger but the problem is not charger but I think is the thunderbolt. I follow some tutorial to flash the correct firmware by a ch431a. First I erase the chip, than flash with a null.bin and finally flash with the TBT.bin padded, but the laptop continue to not charge the batteries. The problem is the two batteries are empty and I can't boot the laptop. My question is: is necessary, after flashing, to boot the laptop to complete the process? So can be this the reason why the thunderbolt not charge batteries also with the new unbugged firmware?
                                    • zomi
                                      • Nov 2011
                                      • 511
                                      Just some help please, I have forgotten how to pad firmware files. Please could someone explain how to do this, spent last evening trying to figure it out, but I can't get my head around it,,
                                      thanks
                                      • Zalman
                                        • May 2020
                                        • 32
                                        • UA
                                        thanks
                                        I use HEX Editor Neo on Windows. Edit - Change file size - 1024kb - save. It will change the size and fill the rest with zeros.
