DA0FL6MB8D0 rev:d need bios
  • String2016
    • Nov 2015
    • 2229
    • philippines
    I need a working bios on this LENOVO board id DA0FL6MB8D0 REV please
  • peste
    • 12627
    • ROMANIA
    Re: DA0FL6MB8D0 rev need bios
    try..
    • String2016
      • Nov 2015
      • 2229
      • philippines
      no working with above bios laptop turns dead here is my backup main
      • String2016
        • Nov 2015
        • 2229
        • philippines
        anyone who have a working dump on this model please
        • String2016
          • Nov 2015
          • 2229
          • philippines
          Anyone
          • peste
            • 12627
            • ROMANIA
            try..
            • String2016
              • Nov 2015
              • 2229
              • philippines
              @peste its working thank you
              • String2016
                • Nov 2015
                • 2229
                • philippines
                update: after hours of using i shutdown and try to turn on issue still came back , but when i reflashed again the chip its working again . what is the problem with this?
                • String2016
                  • Nov 2015
                  • 2229
                  • philippines
                  i think the pch is the culprit i reflowed it turns on again with no problem but when i shutdown and its getting cold same issue
                  • feri
                    • Oct 2011
                    • 10
                    Try this
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • jendkkd jeje
                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                      by jendkkd jeje
                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                      10-11-2024, 03:12 PM
                    • mximiliandz
                      help bios lenovo ideapad s145-14iil type 81w6
                      by mximiliandz
                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                      06-20-2025, 06:50 AM
                    • 1g0r
                      Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                      by 1g0r
                      First, the data in brief:
                      Manufacturer: Lenovo
                      Model: ThinkPad L15 G3 21C3-0016GE
                      motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                      IC Bios 1: MX77L25650F
                      IC Bios 2​: MX25L25673G
                      EC Chip: NPCX997KAABX
                      So far I've been a silent reader, but now I need your help
                      I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                      I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                      The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                      01-18-2025, 02:39 AM
                    • mmy101
                      Looking For Working BIOS of LENOVO LEGION 5 15ITH6
                      by mmy101
                      S/N PF2SAXHJ
                      MTM 82JK0001CC
                      The laptop won't boot. It restarts over and over again, because a hidden BIOS setting - BLCK, was changed from 100 to more than 120+.
                      Need a working bios​
                      Attached files are original dump files from two separate chips on the laptop, and also the BIOS installation file from Lenovo. Wish it helps.
                      Thanks!...
                      12-28-2023, 04:41 PM
