Lenovo E580 bricked after flashing bios ?
  • georgios22
    • Dec 2019
    • 14
    • b
    I have a supervisor locked E580 and i tried to flash it with this bios
    https://www.badcaps.net/forum/showthread.php?t=80837
    (after making a backup of the original)
    The laptop didn't start, the power button light on as well as numlock + caps lock for a second and then it powered off.
    I then flashed back the original, and i see the same behavior...
    If i connect to power the power adapter, the power button flashes 3 times
    Is it bricked?
    I tried disconnecting the cmos battery without success
  • georgios22
    • Dec 2019
    • 14
    • b
    Re: Lenovo E580 bricked after flashing bios ?
    Turns out i need to erase the chip first and then it boots. Anybody has patched bios ? I was searching how to do it but i have multiple BootOption. I don't know witch one to patch.
    • peste
      • Dec 2016
      • 12811
      • ROMANIA
      try..
      • georgios22
        • Dec 2019
        • 14
        • b
        Thanks, after flashing this bios and pressing F1, it asks for a password.
        I tried 1234 but it doesn't work. Any clues?
        • peste
          • Dec 2016
          • 12811
          • ROMANIA
          try this..
          https://1024kb.co.nz/bios/
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            The password is in the SMSC MEC1633L, dxe driver is required for this one.
            • georgios22
              • Dec 2019
              • 14
              • b
              Yes this is the bios i requested/tried to make by patching my own BootOptions and LenovoTranslateService. I guess the fbd i found are for other generation of laptops
              • georgios22
                • Dec 2019
                • 14
                • b
                pete,
                After several wrong attempts it never says Challenge Code to enter on this website.
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1226
                  • France
                  No solution for me for now.
                  Another patch method
                  I'm going to try to make one for you but it won't work I think.
                  • georgios22
                    • Dec 2019
                    • 14
                    • b
                    Thanks for your effort, i've got the same problem. It asks for password and 1234 doesn't work
                    • georgios22
                      • Dec 2019
                      • 14
                      • b
                      I tried another flasher (flashrom on ubuntu) and the laptop has the error code 0285 (0285: TCG-compliant functionality-related error (might be
                      the TPM initialization failure))
                      The same error happens if i try to patch my own bios
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        unsolder the chip and reprogram it with the programmer, under flashrom or other utilities it does not work
                        • battery.12v
                          • 123
                          • NW
                          What do you mean by erasing the chip first then it boots ... cause i have your same problem laptop turn on and off with light 3 times when power adapter is connected
                          • zmezm1995`
                            • Nov 2020
                            • 94
                            • iraq
                            thanks sir
                            • Wahaz
                              by Wahaz
                              10-30-2023, 08:42 PM
                            • Nicola Bianchi
                              Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
                              by Nicola Bianchi
                              Hello!
                              A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
                              No the machine power up, but it stuck in a recovery state and I can not do much.
                              Lenovo X1 Nano Gen 1
                              Type: 20UN - X021US
                              S/N: R9 - 10W2D9
                              I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
                              So here I am to ask for help.
                              I opened the laptop and I found a chip that may be the target, on it I've:
                              Winbond 25R256...
                              01-11-2025, 09:50 AM
                            • JDong
                              Problems flashing BIOS for supervisor locked Lenovo V15 G4 IRU 831A laptop
                              by JDong
                              There was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
                              • Laptop Model: Lenovo V15 G4 IRU
                              • Issue: Forgotten supervisor password.
                              • BIOS Chip: GD25B128E (or GD25B128B
                              07-06-2025, 10:18 PM
                            • q2v5
                              Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                              by q2v5
                              Lenovo T480s
                              Model 20L8-S3TE00
                              Board ET481-U10
                              Chip MX25L12873F
                              Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                              2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                              The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                              08-15-2024, 10:40 PM
                            • grimacelord
                              Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                              by grimacelord
                              Hello there.
                              I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                              History:
                              1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                              I searched for this error online and discovered...
                              03-15-2023, 03:29 PM
