Lenovo Unlock Dxe Driver Bios Collection
This topic is closed.
  • Sjenja
    • Jun 2016
    • 10
    • GoingDownTHeDrainCountry
    #41
    Re: Lenovo Unlock Dxe Driver Bios Collection
    L560 bios patched will work on other machines. No key needed.
    • Andreasbest
      • Aug 2014
      • 1189
      • Hellas ( Greece )
      #42
      How do i use the patche attached in first post?
      I just write it in winbond and follow the procedure:
      Remove all battery and CMOS battery
      press F1 to enter setup: password 1234
      wait 20sec or more.
      Enter any ID to hardware Id.
      Press 2x space bar when asked.
      Turn off the computer.
      and restore your original bios .
      • contact_laptop
        • May 2020
        • 3
        • France
        #43
        Hi everybody,
        New on this forum and french : sorry for my english.
        I've tried to remove a svp password and computrace from a factory X240 that I bought (motherboard VIUX1 NM A091 Rev. 1.0).
        After flashing with patch, no result : when I plugged the AC, the power-on button lights 3 times then the X240 runs automatically but no beeps, no logo, ... I only hear the fan and the screen stays black even if the laptop stays plugged a long time.
        Any idéa, issue to fix it ? Is there an X240 patch available ?
        Thanks for reply and best regards
          • 31157
          if the laptop has a switch on the base/cover you need to keep it pressed.
          • contact_laptop
            • May 2020
            • 3
            • France
            #45
            STJ,
            Thanks for your reply (#47) at my question (#46) : I've pressed a long time the switch on the base cover (little hole near the external battery) without anything plugged (no ac adapter, no battery [ext/int/cmos]) but result is the same.
            Any idéea ?
            Thanks for your answer and best regards
            • Andreasbest
              • Aug 2014
              • 1189
              • Hellas ( Greece )
              #46
              Sorry but my english aren't so good so i have a noob question.
              When i try to enter bios i get the screen in attachment.
              The procedure on this thread to unlock DXE driver will remove it??
              • aleksandaralex
                • Jan 2016
                • 10
                • Serbia&Montenegro
                #47
                yes, if you make a patched bios and go through the procedure
                https://www.badcaps.net/forum/showpo...72&postcount=1
                • Andreasbest
                  • Aug 2014
                  • 1189
                  • Hellas ( Greece )
                  #48
                  So i just backup my original dump
                  i store it
                  then i write the patched T440 that is available in the post that you show me
                  i follow the procedure
                  and BIOS password is gone forever?
                  • aleksandaralex
                    • Jan 2016
                    • 10
                    • Serbia&Montenegro
                    #49
                    i store it
                    send the bios here, someone will already patch it for you...
                    I don't believe it will go with the bios from post #1.
                      • 21452
                      The OP at post #1 requested that only patched working files are posted in this thread
                      Quote:
                      Please,you can add your file patched and model version for add to the collection.
                      Thanks to add patch only OK.
                      For a password release request, please use the other page. https://www.badcaps.net/forum/showthread.php?t=65996
                      You can post your patch here, if only this one worked !!
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        #51
                        Originally posted by contact_laptop
                        STJ,
                        Any idéea ?
                        That's the wrong switch. Black switch, not white.
                        • Andreasbest
                          • Aug 2014
                          • 1189
                          • Hellas ( Greece )
                          #52
                          So the files from #1 post (Lenovo T440 in my case) will work in both T440 that i got, right?
                          • aleksandaralex
                            • Jan 2016
                            • 10
                            • Serbia&Montenegro
                            #53
                            NO Bro,
                            not worked,
                            pls post your t440 bios dump on this thread:
                            • Andreasbest
                              • Aug 2014
                              • 1189
                              • Hellas ( Greece )
                              #54
                              I try in T440.
                              Flashed the patched file but screen remains black, only power led on
                              I put some adhesive tape in bottom switch,
                              • dihcar84
                                • Aug 2012
                                • 199
                                • morocco
                                #55
                                thank you sooooo mutch
                                • xmasterboss
                                  • Apr 2014
                                  • 34
                                  • Romania
                                  #56
                                  No. Bought new TL866 II Plus to read 256MB BIOS. If someone can inject patch, i can post BIOS here.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1189
                                    • Hellas ( Greece )
                                    #57
                                    You can buy the DXE patch from here https://www.allservice.ro/forum/viewtopic.php?t=3044 (80$) and then post it here to patch it and make it work in all T490. Plus you help the community
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      #58
                                      Looks like not possible right now : D Only available in their service store.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1189
                                        • Hellas ( Greece )
                                        #59
                                        Do they mean exclusively OR laptop must be sent in their store?
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #60
                                          Looks like temporarily available only in their store. So it might be available remotely at a later time.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • remizbushka
                                            Dell inspirion 5775 bios "Unlock Setup fail"
                                            by remizbushka
                                            Hi sirs. please help
                                            Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                            After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                            What I did:
                                            I read the bios dump.
                                            Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                            03-24-2025, 09:07 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
