Need DAG75AMBAD0 Bios File
  • bilen
    • Aug 2014
    • 638
    • istanbul
    Old Dump deleted
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Need DAG75AMBAD0 Bios File
    try and report
    • peste
      • Dec 2016
      • 12941
      • ROMANIA
      try...
      • bilen
        • Aug 2014
        • 638
        • istanbul
        Originally posted by peste
        try...
        no working.
        • bilen
          • Aug 2014
          • 638
          • istanbul
          Originally posted by Claudiomfa
          try and report
          image comes in 30 seconds
          fan rotates too fast and gives this error
          shut down when enter
            • 21145
            Both those bios posted are BID0836B (KABYLAKE H) ,the bios update has 4 different ones. Check your cpu ID by the part number on the CPU,or check the laptop models spec page,get the bios from: https://www.badcaps.net/forum/showthread.php?t=81556
            • bilen
              • Aug 2014
              • 638
              • istanbul
              okey . thank you.
                • 21145
                Ok . What is the full laptop model number ?
                • zkirac
                  • 5
                  • turkey
                  Hi did you solve this problem i have 2 machine the same problem i checked cpu model and used correct bid bios dump nothing changed..
                  Also i tried all suitable ME file but still delay 45 seconds.
                  //Turkish/
                  Merhaba Ben de aynı sorunu yaşadım doğru bid numaralı biosu da yazdım düzelmedi üstelik ME de olmadı siz çözebildiniz mi bu sorunu ? kapatıyor kendisini fanlar çalışıp
                  • Dinneke
                    • Apr 2014
                    • 154
                    • Netherlands
                    Any solution please?
                      • 21145
                      Try the virgin bios and EC, if it doesn`t work then your problem is somewhere else. https://www.badcaps.net/forum/showthread.php?t=81556
                      • Dinneke
                        • Apr 2014
                        • 154
                        • Netherlands
                        How program EC without EC programmer?
                        • no3mangroup
                          • Jul 2014
                          • 59
                          • egypt
                          please need ec file for this model
                          • ameerrrr
                            • Aug 2015
                            • 41
                            • syria
                            I need to clear the password and worg clean me
                            sn 2TK12700Q7​
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
                          • bondminer009
                            Need Bios for Latitude 7650 (No Original / dump bios file)
                            by bondminer009
                            Good Evening,
                            Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                            Thank You
                            Salam,
                            Three
                            11-12-2024, 07:48 AM
                          • joshAU
                            BIOS file for N550JK (original dump attached)
                            by joshAU
                            Hi all.
                            I'm looking for a BIOS file for an Asus N550JK.
                            I have a Asus R552J, which I believe is identical to the Asus N550JK.
                            I downloaded the latest BIOS (210) for the R552.
                            It is named N550JKAS.210.
                            The BIOS file is however only 6mb in size.
                            I've read the chip with a CH341A programmer and verified the file.
                            That file is actually 8mb in size.
                            I'm wanting to remove the BIOS password from this unit.
                            It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                            08-09-2022, 08:06 PM
                          • adelage
                            Merge ECS Z77-H2 bios cap file with original dump
                            by adelage
                            I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                            03-11-2025, 03:07 AM
                          • silverflea
                            Need Bios MSI B75A G43 Dump File
                            by silverflea
                            Hi. I need dump file bios MSI B75A-G43
                            My bios got corrupted and wont boot, so i need to flash it using Ch341A programmer, but bios file from the official website is to large, so i need bios dump file from working motherboard, or anyone know how to cut the bios size to fit bios chip
                            Thanks!
                            08-09-2022, 01:37 AM
