vostro 3400 bios
  • Dangvantu
    member
    • Apr 2024
    • 43
    • Vietnam
    #141
    Originally posted by qayyum786
    Did you cross check with another good hdd and ram ?
    Thanks dude works fine
    • electronica
      • Apr 2014
      • 89
      • algeria
      #142
      Originally posted by biber
      i have used this bios whithout service tag, you can enter it in bios/system manamament manually. also using alt+f you can exit from "manufacturing mode active" choosing your laptop model
      thank you working
      • kodinabeel
        • Sep 2014
        • 66
        • saudi arabia
        #143
        Hello, I need help with the bios of a vostro 3400 pcb LA-K032P
        service tag 6GX4MB3.
        thank you so much​
        • peste
          • 13924
          • ROMANIA
          #144
          thank you so much​
          post the original content of the bios chip, even if it is corrupted..
          • kodinabeel
            • Sep 2014
            • 66
            • saudi arabia
            #145
            its coming flash boot error..
            • shiyab
              • Sep 2023
              • 1695
              • india
              #146
              post snid
              • kodinabeel
                • Sep 2014
                • 66
                • saudi arabia
                #147
                Originally posted by shiyab
                post snid
                pls check this video,this error coming continuously...
                • ntec
                  • Jun 2020
                  • 55
                  I have a Vostro 3400 that turns on with spinning fans but no display then shuts off after 4 seconds so not sure if it's a corrupt bios so want to try a fresh bios before I dive deeper into a board issue. Attached is my dump from the 2 bioses.
                  Board model: LA-K034P Rev 1.0
                  Service tag: BVV72D3
                  • qayyum786
                    • Aug 2018
                    • 1959
                    • INDIA
                    #149
                    Try
                    • ntec
                      • Jun 2020
                      • 55
                      Try
                      Thanks, it worked!
                      • ntec
                        • Jun 2020
                        • 55
                        I fixed a dell vostro 3400 that had a bad bios so i reflashed a working one. I have tried looking at the old bios dump for the windows key but I could not find any key. Maybe the old bios was corrupt which corrupted the section with the windows key but could someone look at the attached dump to see if the windows key is indeed gone?
                        • peste
                          peste commented
                          Editing a comment
                          post merged..
                      • madushanka 1234
                        • Apr 2019
                        • 71
                        • sri lanka
                        #152
                        ANYONE CAN FIX MY ORIGINAL BIOS FILES???
                        FAULT-NO POWER
                        I TRIED OTHER FILE POWER ON BUT SOUND NOT WORKING/ & TPM ERROR
                        I NEED REPAIR MY OLD BIOS
                        OLD BIOS BOTH ATTACHED
                        • 22279
                        Post the service tag please https://www.badcaps.net/forum/troubl...before-posting
                        Both bios you posted are identical, apart from the filesize, so you`ve done something wrong . Compare your 16MB backup with the 16MB bios at post 165
                        • ntec
                          • Jun 2020
                          • 55
                          Service tag is BVV72D3
                          • dikmen
                            • Apr 2015
                            • 49
                            • TURKIYE
                            #155
                            Originally posted by rex98
                            Re: vostro 3400 bios
                            us this it works 100% flash both MAIN and EC according to your model 32 or 33. put service tag in first boot and done.
                            This is suitable in two models Dell Vostro 3400 and Inspiron 3501 only.
                            Idk if this works in VOSTRO 3500 just try if u want.
                            give feedback
                            This bios worked on vostro 3500 la-k032p, but it gives a warning that no device to boot is found and does not boot.​
                            • Informatech CG
                              • Jun 2024
                              • 7
                              • Brazil
                              #156
                              Hello, need help with the bios of a
                              Vostro 3400 PCB LA-K034P
                              service tag 4G68PH3.
                              problem is 3 amber one 1 white blink and won't turn on. tried w/ other bios and still the same.
                              • nonomanita
                                • Feb 2018
                                • 30
                                • algeria
                                #157
                                plz fix my bios
                                DELL Vostro 3400
                                Service Tag: 3M70YM3​
                                MOTHERBOARD : LA-K034P REV:1.0 (A00)
                                • LBTT1121
                                  • Nov 2024
                                  • 1238
                                  • Việt Nam
                                  #158
                                  Originally posted by nonomanita
                                  plz fix my bios
                                  DELL Vostro 3400
                                  thử # 149 https://www.badcaps.net/forum/troubl...39#post3533639
                                  • Informatech CG
                                    • Jun 2024
                                    • 7
                                    • Brazil
                                    #159
                                    service tag 4G68PH3.​
                                    I try w/ others BIOS and I have news... before my laptop dont turn on, make CLEAR ME in my BIOS and now my laptop turn on, but the message "MANUFACTURING MODE ACTIVE" is always show!!! Someone for help me?
                                    • nonomanita
                                      • Feb 2018
                                      • 30
                                      • algeria
                                      #160
                                      - use external keyboard (usb keyboard) and press ALT+F
                                      - then chosse your model laptop
                                      - finally go to bios and write SERVICE TAG
                                        DELL Vostro 3471 Vostro 3400 i3-9100 Specification for Upgrade or Repair
                                        This specification for the DELL Vostro 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3471 boardview and Vostro 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                        09-12-2024, 03:44 PM
                                        DELL Vostro 3470 Vostro 3400 i5-9400 Specification for Upgrade or Repair
                                        This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                        DELL Vostro 3470 Vostro 3400 i5-8400 Specification for Upgrade or Repair
                                        DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
