vostro 3400 bios
  • maykol27
    • Oct 2022
    • 7
    • bolivia
    #101
    yes sir all fine i put same bios other laptop same blue screen
    the bios is fine but has problem to work windows
    u dont have other bios with patch please
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      #102
      Do you have a original backup ?
      • nisham
        • Mar 2018
        • 7
        • India
        #103
        la-k032p after bin bios change giving error MANUFACTURING MODE ACTIVE press ALT FN and fan running with full speed can anybody fix this
        service tag- 7q4s1d3
        • Rockhardware2
          • Dec 2018
          • 5
          • Togo
          #104
          Hi guys. Dell vostro 3400 motherboard la-k032p rev 1.0 with no display. help please
          service tag JYXYTC3
          This is old dump
          • rex98
            • Feb 2023
            • 1293
            • Mandaue CEBU, Philippines
            #105
            service tag JYXYTC3
            This is old dump
            try flash that both
            • maxmactec
              • Jan 2024
              • NICARAGUA
              #106
              Hello, I have a Dell Vostro 3400 i3 11th board: GDI4A LA-K034P REV 1.0 with ST:FD77JK3 I need the BIOS, the others that I have installed make the fan at 100% and sends a message "MANUFACTURING MODE ACTIVE press ALT FN" and the BIOS says that it is a 3500 when mine is a 3400, I do not have the original BIOS, thank you very much
              DELL VOSTRO 3400
              SERVICE TAG FD77JK3
              • Muhammad Faizan
                • Mar 2022
                • 32
                • 000
                #107
                I Have vostro 3400 GDI4A LA-K034P After bios update Sound not work fix this orignal bios.
              • Muhammad Faizan
                • Mar 2022
                • 32
                • 000
                #108
                Vostro 3400
                S/N 11ZXZK3
                sound not come its urgent fix this problem
                • rex98
                  • Feb 2023
                  • 1293
                  #109
                  Originally posted by Muhammad Faizan
                  Vostro 3400
                  S/N 11ZXZK3
                  here try
                  • Muhammad Faizan
                    • Mar 2022
                    • 32
                    • 000
                    #110
                    no power
                    • lord
                      • May 2011
                      • 319
                      • Croatia
                      #111
                      Please Fix, no picture.
                      Dell Vostro 3500
                      SN: G3Q0VC3
                      LA-K032P
                        • 21968
                        Dell Vostro 3500
                        SN: G3Q0VC3
                        LA-K032P
                        Use the forum search,find a Vostro 3500 thread to post your request in.This thread is for the 3400
                        • lord
                          • May 2011
                          • 319
                          • Croatia
                          #113
                          Oouch, thanks for the heads up
                          • biber
                            • Feb 2015
                            • 104
                            • macedonia
                            #114
                            Hello, need help with the bios of a
                            Vostro 3400 PCB LA-K034P
                            service tag 1SC25N3.
                            problem is 3 amber one 1 white blink and won't turn on. tried new battery still the same. tried random bios from previous posts but fan is spinning 100% and "manufacturing mode active"
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12336
                              #115
                              Vostro 3400
                              Service Tag: 1SC25N3
                              • biber
                                • Feb 2015
                                • 104
                                • macedonia
                                #116
                                Originally posted by hoaca388
                                Vostro 3400
                                same behavior :/ no image blinking lights.
                                but i have image and boot but fan is spinning 100% and "manufacturing mode active" with bios that i will attach in this post. can you edit this bios and insert my service tag pls?
                                • biber
                                  • Feb 2015
                                  • 104
                                  • macedonia
                                  #117
                                  i have used this bios whithout service tag, you can enter it in bios/system manamament manually. also using alt+f you can exit from "manufacturing mode active" choosing your laptop model
                                  • Nano Zambrano
                                    • May 2024
                                    Hi there, please help me. My Dell Vostro 3400 does not have set the ownership date and the manufacter date in the BIOS, both value appear to be set as {none} Do you know if I can solve this issue flashing a patched BIOS?
                                    My service tag does not seem to be a valid one, but it is the same from the sticker in the cover.
                                    SERVICE TAG: 6NW20H3
                                    The thing with both date is that this laptop does not charge past the 55%, I found a troubleshooting guide in Dell website to get this issue solved setting a proper ownership date and a manufacter date, but this guide is for older models where can be set up in the BIOS System but this Vostro 3400 does not have the same interface.
                                    • LOBOGRIS
                                      • Sep 2016
                                      • juigalpa
                                      #119
                                      Ayuda con BIOS corrupta. Por favor alguien que me ayude se lo pido humildemente.
                                      Dell Vostro 3400
                                      3BH80H3
                                      • qayyum786
                                        • Aug 2018
                                        • 1959
                                        • INDIA
                                        #120
                                        Dell Vostro 3400
                                        3BH80H3
                                        post should be in ENGLISH if you don't know then you may use google translate
                                        la publicación debe estar en INGLÉS si no lo sabes, entonces puedes usar
                                          DELL Vostro 3471 Vostro 3400 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3471 boardview and Vostro 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                          09-12-2024, 03:44 PM
                                          DELL Vostro 3470 Vostro 3400 i5-9400 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                          DELL Vostro 3470 Vostro 3400 i5-8400 Specification for Upgrade or Repair
                                          DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
