Re: HP ProBook 450 G3
Yes yo should remove 3v battery before soldering the new dumb
enter Bios setup : F10 and go/search to security tab , you will find reset security settings to default
HP ProBook 450 G3
thanks for the new bios. is there any procedure specific after flashing and soldering it back on?
clearing pram or soemthing by removing the 3V battery?
What security tab are you talkign about?Leave a comment:
Attached FilesLeave a comment:
Hello, I need to fix the bios for HP Pro Book 450...
DAX63CMB6D0
REV
Serial 5CD8396330
MANY THANKS
this one work for me if some one need itAttached FilesLeave a comment:
thank you hoaca388 i see en me analyzer that the backup sku is consumer LP
and yours sku is corporate LPLeave a comment:
Hi please i need a working dump for hp probook 450 g3
mb : Dax63cmb6d1 rev d x63c
black screen
this is my backup
all voltage ok
I TRIED OFICIAL PAGE HP BUT ITS JUST 9MB AND I TRIED CLEAN ME BUT STILL THE SAME I THINK ITS CORRUPTEDAttached FilesLast edited by ismaelstepheno; 10-18-2022, 06:05 AM.Leave a comment:
plz i need to fix my old bios for hp probook 450 G3 DAX63CMB8D0
laptop can t display
thank !Attached FilesLeave a comment:
Hi, can someone check it for me beeps 3 long 2 short, I try bios from forum, and they're turning with factory mode but without all id's of devices and other information. I presume that they n my old bios dump can anyone combine them, I attach my old bios that is not working.Attached FilesLeave a comment:
thanks a lot it works, i had to find out system board ct number, feature byte, Build ID... i put all of those information. have some doubt about system board ct number.
BUT IT WORKS THANKS TO YOU!!Leave a comment:
Hi there i need help with this dump, and shema wil be ok
mobo nomber is:
DA0X63MB6H1 REV:HAttached FilesLeave a comment:
by AhariHi all,
I...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
