HP ProBook 450 G3
  • skazide
    replied
    Re: HP ProBook 450 G3
    Originally posted by dpanijan
    450 G3, two long two shorts, BIOS corrupted. Got laptop as non-working.
    Serial 5CD6104L89
    Flashed BIOS from https://www.badcaps.net/forum/showpo...68&postcount=2 and it boots and works, but after BIOS update from Windows to new version, charger is not working. Flashed back via programmer, working.
    Also, I thing there should be dGPU, but not showing.
    Please suggest other BIOS
    Many thanks
    post not working old bios if you stil have
  • dpanijan
    replied
    Serial 5CD6104L89
    Many thanks
    Motherboard DA0X63MB6H1 rev.H
  • dpanijan
    replied
    Serial 5CD6104L89
    Many thanks
  • motanya
    replied
    Originally posted by peste
    it has EC bios....you can change them if they are identical, but you will have to write the 430g3 chip with the 450g3 content..
    Thank you, somebody help me with the ec please
  • peste
    replied
    Originally posted by motanya
    Does 450 g3 have a bios EC? Can i replace the nuvoton kbc with that of 430 g3, they are the same from the labeling.
  • motanya
    replied
  • peste
    replied
    Originally posted by rioda91
    Originally Posted by rioda91 View Post
    hello everyone, I have a problem with a 450 g3, I think I made some mistake because I' ve done a backup of his locked bios and try to unlock it with no result.. but now whet I try to insert back on the pc the original one doesn' t work! maybe there is something wrong with the backup, I don' t know.. Is there a method to make a clean bios? how can be do?
    Now I have found on web a bios of a 430 g3 that works but take a minute before hp logo
    I' ll attach the original
    https://www.badcaps.net/forum/showthread.php?t=103526
  • rioda91
    replied
  • rachidell
    replied
    Originally posted by qayyum786
    try
    thank you it's work
  • qayyum786
    replied
    Originally posted by rachidell
    hello,
    please clean my dump.
    Thanx
    try
  • rachidell
    replied
    thanx
  • CornholioGSM
    replied
    thx
  • walkfire
    replied
    Thx for reply, i tried it before with this same efect. I think my MB is dead
  • peste
    replied
    Originally posted by walkfire
    Peste can you help me with this bios dump ?
    try post #2
    https://www.badcaps.net/forum/showthread.php?t=65561
  • walkfire
    replied
    Thx peste, my original post with bios dump is three posts up. Symptomps are 3x long beep and after 2x short beep, black screen and after 10s max speed fan
  • walkfire
    replied
  • peste
    replied
    Unfortunately I have the same symptom
    what symptom??what problem do you have??post the original bios of the laptop...
  • walkfire
    replied
  • hardware1
    replied
    Hello, anyone can fix my bios for HP Probook 450 G3 DAX63CMB6C0 REV.C with nvidia GFX. 3x long beep an 2x short i changed RAM modules but still black screen and fast fan.
    Here's your New Bios file, try it and give me the results.
    Serial Number: 5CD6246QSH.
  • walkfire
    replied
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • haitham sharabati
    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
    by haitham sharabati
    Hello engineers 😀,
    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
    💀 Problem:😅
    - Device shows “Administrator Password”...
    08-07-2025, 04:54 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
