HP ProBook 450 G3
  • lapfix
    replied
    Re: HP ProBook 450 G3
    Originally posted by master_clone33
    thanks for the new bios. is there any procedure specific after flashing and soldering it back on?
    clearing pram or soemthing by removing the 3V battery?
    What security tab are you talkign about?
    Yes yo should remove 3v battery before soldering the new dumb
    enter Bios setup : F10 and go/search to security tab , you will find reset security settings to default
  • master_clone33
    replied
  • lapfix
    replied
    Hello, I need to fix the bios for HP Pro Book 450...
    DAX63CMB6D0
    REV
    Serial 5CD8396330
    MANY THANKS
    Go to security tab and reset security settings to default
  • master_clone33
    replied
    DAX63CMB6D0
    REV
    Serial 5CD8396330
    MANY THANKS
  • faradaille
    replied
    Bios of dylen is the working bios
  • ismaelstepheno
    replied
    this one work for me if some one need it
  • ismaelstepheno
    replied
    thank you hoaca388 i see en me analyzer that the backup sku is consumer LP
    and yours sku is corporate LP
  • hoaca388
    replied
    Originally posted by ismaelstepheno
    Hi please i need a working dump for hp probook 450 g3
    mb : Dax63cmb6d1 rev d x63c
    black screen
    this is my backup
    all voltage ok
    I TRIED OFICIAL PAGE HP BUT ITS JUST 9MB AND I TRIED CLEAN ME BUT STILL THE SAME I THINK ITS CORRUPTED
    Try
  • hoaca388
    replied
    Originally posted by YOUN
    plz i need to fix my old bios for hp probook 450 G3 DAX63CMB8D0
    laptop can t display
    thank !
    Here
  • ismaelstepheno
    replied
    black screen
    this is my backup
    all voltage ok
  • YOUN
    replied
    thank !
  • Masanori
    replied
    Originally posted by hoaca388
    HP ProBook 450 G3 Notebook PC
    Thank you very much! hoaca388!
    With the BIOS you repaired, my computer now boots! :-)
  • sebawilq
    replied
    Working excellent magic
  • hoaca388
    replied
    Originally posted by sebawilq
    Hi, can someone check it for me beeps 3 long 2 short, I try bios from forum, and they're turning with factory mode but without all id's of devices and other information. I presume that they n my old bios dump can anyone combine them, I attach my old bios that is not working.
    Serial number : 5CD5487Y75
  • sebawilq
    replied
  • nagkhal
    replied
    thanks a lot it works, i had to find out system board ct number, feature byte, Build ID... i put all of those information. have some doubt about system board ct number.
    BUT IT WORKS THANKS TO YOU!!
  • hoaca388
    replied
    Originally posted by nagkhal
    Hi there i need help with this dump, and shema wil be ok
    mobo nomber is:
    DA0X63MB6H1 REV:H
    ProBook 450 G3
  • nagkhal
    replied
    mobo nomber is:
    DA0X63MB6H1 REV:H
  • nagkhal
    replied
    HP probook 450 G3 DA0X63MB6H1 REV H, please need help with my bios Dump, wont boot with my corrupted bios.
    thank you
  • leo042188
    replied
    Not Work Bios
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • haitham sharabati
    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
    by haitham sharabati
    Hello engineers 😀,
    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
    💀 Problem:😅
    - Device shows “Administrator Password”...
    08-07-2025, 04:54 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
