hp 840 g6 6050A3022501-MB-A01
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1226
    • France
    #101
    Re: Problem with elitebook 840 g6 bios
    Originally posted by estabilito
    Hello, i need to remove password Hp elitebook 840 g6.
    After trying to program with known good bios with org me region it works without password but hp endpoint problem shows on boot.
    Posting org dump files 32mb and 16mb.
    try this ,just 32mo patch make with hp unlocker
    Originally posted by peste
    you still have a 16MB bios chip on the board, look on both sides of the motherboard.. ..
    as @peste indicated before, it will surely be necessary to make the two bios 16 and 32 mo
    • estabilito
      • Aug 2020
      • 54
      • poland
      #102
      Re: hp 840 g6 6050A3022501-MB-A01
      No hp endpoint fault but unfortunately password is still here
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1226
        • France
        #103
        please try
        i not believe
        • estabilito
          • Aug 2020
          • 54
          • poland
          #104
          should i use org 16mb file or this from Peste?
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            #105
            try org 16mo
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #106
              Try (program both chips)
              Become a Badcaps supporter
              Thanks to all supporters.​
              • estabilito
                • Aug 2020
                • 54
                • poland
                #107
                with these two files: keeps restarting with no image.
                • estabilito
                  • Aug 2020
                  • 54
                  • poland
                  #108
                  Originally posted by Maxpower3
                  try org 16mo
                  dont even start with this and org 16mb chip
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1226
                    • France
                    #109
                    @peste ,Vesko356
                    Nobody has found the modification to make in the 16Mo so that it's clear?
                    instead of putting everything virgin each time.
                    many times are written AdminPw inside but corresponds to bios settings.
                    must have a volume or padding to modify??
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #110
                      Edited:
                      • estabilito
                        • Aug 2020
                        • 54
                        • poland
                        #111
                        Edited:
                        after bios restart fan stay on highest rpm and no image.
                        • peste
                          • 12822
                          • ROMANIA
                          #112
                          try..
                          • estabilito
                            • Aug 2020
                            • 54
                            • poland
                            #113
                            try..
                            Working without password and any errors, Thanks!
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1226
                              • France
                              #114
                              good job of peste
                              • mmarji
                                • Nov 2018
                                i uploaded bios for an hp 840 G6 with password, can anyone be able to remove it.
                                thank you
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #116
                                  thank you
                                  Your 32mb dump is not ok, before proceeding any further backup content of the chip correctly!
                                  After that program 16mb chip only:
                                  • Kim_555
                                    • Jan 2014
                                    • Kiev
                                    #117
                                    Hi, please help me. I tried a clean BIOS from this post - it works, the password is cleared. I registered the serial numbers manually, but with it the laptop stopped detecting the nvme pciexpress hard drive, only sata
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #118
                                      Try and leave feedback:
                                      • Kim_555
                                        • Jan 2014
                                        • Kiev
                                        #119
                                        Thanks, all ok
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #120
                                          Thanks, all ok
