Acer E1 430 bios
  • Fekyyy
    • Nov 2019
    • 8
    • Hrvatska
    Acer E1 430 bios
    Ok, first of all, i'll describe situation-i changed BIOS settings, but only from UEFI to legacy, saved, restart laptop, than it showed i cant boot my system, some file is missing, but i planed to install new system, so i didn't care, restarted to enter to BIOS again so i can change boot devices but just black screen, no beeps for some error or something and cant do anything since then...
    I tried to reset BIOS, nothing, changed battery, still nothing, checked RAM, it is good, connect it on tv, nothing, pressed fn+f5 and fn+f6, still nothing
    Tried all solutions that i could find, except recovery BIOS, because i dont have another pc or laptop...
    I believe it's BIOS problem, cause everything worked ok before i changed from UEFI to legacy...
    When i press power key, i see hdd led blink on one second, and after that nothing, but i hear fan and even hdd, but very quiet, power led is on
    Maybe if someone could provide me files, maybe i could try recovery BIOS by put that files on usb with phone
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Acer E1 430
    you need to reprogram the Bios chip using an external programmer.
    • Fekyyy
      • Nov 2019
      • 8
      • Hrvatska
      Re: Acer E1 430
      Do i need some special model or?
      Do you have some recommendation
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Re: Acer E1 430
        any model would be enough for programming a SPI IC.
        If you buy an expensive programmer, it is probably able to program a wider range of ICs compared to a cheap one.
        • Fekyyy
          • Nov 2019
          • 8
          • Hrvatska
          Re: Acer E1 430
          And what about crisys or however it's called, i read there is some chance of bios recovery with usb, however i need pc to reprogram bios
            • 22276
            Re: Acer E1 430 bios
            You would need a full bios dump to attemt a crisis recovery, your bios is a phoenix bios. The acer support page only has a bios update not the full bios.Unless you can find a bios dump or one of the members posts one you will have to buy a bios programmer and make a backup. The CH341A programmer is very cheap, if you can`t desolder the bios you also need a sop8 clip, and if the bios is 1.8V you need an adapter for that.
            https://www.aliexpress.com/item/32966157204.html
            https://www.aliexpress.com/item/4000192637141.html
            • Fekyyy
              • Nov 2019
              • 8
              • Hrvatska
              This is my MB
              If this can help
              • Fekyyy
                • Nov 2019
                • 8
                • Hrvatska
                I found some file on internet and put it on usb and when i try to recovery bios, usb light is on, and i already tried with different files, but none of them made usb light on, only this one, but there is still nothing happening
                  • 22276
                  Try this bios from post #6 https://www.badcaps.net/forum/showthread.php?t=59394
                  • akdenizmusty
                    • Aug 2016
                    • 46
                    • Turkey
                    Have on official site
                    https://dosya.co/blrdux43wagr/ZQS.rar.html
                      • 22276
                      Originally posted by akdenizmusty
                      Thats a bios update ,not full bios.No ME ,management engine.
                      • Fekyyy
                        • Nov 2019
                        • 8
                        • Hrvatska
                        Originally posted by SMDFlea
                        I tried but nothing, i found some other bios, but for some other model of laptop with same MB, usb stick led is on, and with none of others wasn't, but still nothing happening
                        Maybe i need to change name, i'm not sure, but if i'm right, i don't know which name i should put
                        • Fekyyy
                          • Nov 2019
                          • 8
                          • Hrvatska
                          Does anyone know how should i rename file, i tried few files, but nothing happens, and maybe i just to put some other name, i'm so angry on acer, cause there are tons of ppl having this problem
                          • EbrahimSiami
                            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                            by EbrahimSiami
                            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                            **What I have tried so far:**
                            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                            07-02-2025, 02:31 PM
                          • Wg188
                            ACER Veriton Z4660G AIO bios help
                            by Wg188
                            I have an Acer veriton Z4660G all in one pc,
                            Model: Z4660G-I5850H1 (VZ4660G_W)
                            Need bios dump and schematic would save my life !
                            to make a long story short I bought this all in one used
                            with a broken lcd, with the objective of making a custom desktop out of it
                            ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                            06-17-2023, 02:20 PM
                          • throwaway327
                            by throwaway327
                            Model No: RC72LA
                            Serial No: SBNVKD001014459
                            06-18-2025, 05:52 PM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • James194zt
                            Acer Nitro 50-640E Corrupted BIOS Dump
                            by James194zt
                            My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                            All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                            04-28-2025, 03:29 PM
