ACER R5-471T-534X Bios
  • mferna14
    • Jun 2018
    • 1050
    Hi, does anyone have the BIOS bin file for ACER R5-471T-534X (MFG Date: 2015-11-17). I would appreciate if someone could help. Thanks
    • 22275
    Re: ACER R5-471T-534X Bios
    Post your bios backup .
    • mferna14
      • Jun 2018
      • 1050
      I can't even read the chip MX25L64473E., Its detects perfectly but when read time, gives errors "Cannot read"... I am still trying to read, maybe might get luck
      • mferna14
        • Jun 2018
        • 1050
        Ok I got the chip to read, I have no idea how, but still when I solder the chip back again, still motherboard does not turn on... May chip & program is defective. Here is the dump though, hope it help & gets me a NEW clean dump.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Try this bios. Your bios merged with acer bios update+DMI data+Win Key.
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • Danfay
            Acer Aspire 3 A317-51G Request Bios in .bin file
            by Danfay
            Hello, I have an Acer Aspire 3 A317-51G, with a QH128AHIG XMC chip.
            Due to a problem when I turn off the computer, I tried to upgrade the bios through Windows (10), this is the only possibility to update in Acer. Unfortunately, something went wrong . The laptop starts but I can't even access the Bios. I searched for a long time, without success, for the Bios version in .bin file .
            The last functional Bios version was: InsydeH20, Rev. 5.0, Version 1.09 .
            So I updated to version 1.11, which apparently either went wrong or is not functional.
            Does anyone...
            09-25-2023, 02:57 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
