Lenovo ThinkPad T470s BIOS
  • mferna14
    • Jun 2018
    • 1026
    Re: Lenovo ThinkPad T470s BIOS
    Use Bin File in Post #36 .. might help you
    • Marian Gabriel
      • Jun 2023
      • Romania
      #42
      Hi. I need bios t470s type:20JT-S06X00 SNPC0QW188. My bios is blocked. Please help!
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #43
        Read the rules before posting:
        BIOS guides, methods, resources and tools
        Password removal by laptop brand
        Become a Badcaps supporter
        Thanks to all supporters.
        • Marian Gabriel
          • Jun 2023
          • Romania
          #44
          Thanks anyway, I solved the problem with youtube myself..
          • chris_at
            • Apr 2023
            • Österreich
            #45
            anyone got a BIOS file I can use for my T470s 20HF-0047GE PC-0L6NAM?
            Reason for request. After "normal" BIOS update the laptop did not start anymore. Not even into the BIOS.
            I was hoping to get it back working by flashing it via AsProgrammer but need a working bios dump for that.
            • chris_at
              • Apr 2023
              • Österreich
              #46
              Originally posted by hoaca388
              T470s (type 20HF, 20HG) Laptop (ThinkPad) - Type 20HG
              Thankts! Worked fine for me although using a clamp.
              Seems it was necessary to delete the BIOS first from the chip as otherwise the re-read was consistently (write-read always returned the same files so flashing via the clamp seemed to work) different from the original file.
              • willywilly
                • Apr 2019
                • 3
                • kenya
                #47
                hi.the link doesn't work
                • nikola07
                  • Sep 2018
                  • 36
                  • Ukraina
                  #48
                  please help. I need a dump of u15 chips. This is a dump of usb type c.nm-b081 rev 1.0
                  • hzeng
                    • Nov 2023
                    • 4
                    • China
                    #49
                    Thank you, hoaca388 for this bin file. I used it for flashing my T470s 20HF. This laptop can only boot to see some flashes of the keyboard light after the late BIOS update using Think Vantage from Lenovo. Now I can at least boot into BIOS setup page after flashing this BIOS file with a new bought CH341a programmer. And thanks to @dahnking for the confirmation of working.
                    However, after some other fixes (patching with BIOS AutoPatcher by @Knucklegrumble ), I finally got into my Windows 10 system. Then, I found that the Fn key not working, but the Esc key worked for the function of Fn key. I think this may be because of the type does not match.
                    Still, thanks a lot.
                    • hzeng
                      • Nov 2023
                      • 4
                      • China
                      #50
                      Originally posted by hzeng
                      ... Then, I found that the Fn key not working, but the Esc key worked for the function of Fn key. I think this may be because of the type does not match.
                      UPDATE: This is because that I have not modify the setting in BIOS to make F1...F12 function primary.
                      • justShowMeTheDownload
                        • Oct 2023
                        • 4
                        • Poland
                        #51
                        I've tried a few programmers with the CH431A Pro, and the only one that could detect the chip was AsProgrammer, but it only seems to support the W25Q128BV and W25Q128FV chips. Any help?
                        [Edit] I've found this one, and it programmed it properly!
                          • Oct 2023
                          • 4
                          • Poland
                          #52
                          My bios wont open after trying to programm the patched binary. It's stuck on "Entering Setup....". Here is my original bios dump, please help me
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11798
                          #53
                          Serial number ?
                          • Oct 2023
                          • 4
                          • Poland
                          #54
                          I still need help with this, restoring the backup of the bios doesn't fix the problem, I cannot upload it here, nor post a link to it. I feel cornered, I really need this machine to work.
                          Also, if I do not enter bios, I get two errors:
                          0271: Check Date and Time settings.
                          0183: Bad CRC of Security Settings in EFI variable.
                            • Oct 2023
                            • 4
                            • Poland
                            #55
                            Okay, I've tried it again today with a different programmer, and it works! And the password is down too!!!
                            For future users that might struggle with this too, I've used NeoProgrammer, downloaded from here.
                            • kulokutoys
                              • Jun 2010
                              • 132
                              • Phillippines
                              #56
                              Device: Laptop
                              Brand: lenovo T470s
                              type: 20JT-S04Y2L
                              SN: PC0LPH9U
                              Request: Repair
                              Turning on but no post, with musical sound, lenovo PC diagnostics error 0285 TCG compliant fuanctinality related error ( might be the tpm initialization failure) ​
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11798
                                #57
                                Originally posted by kulokutoys
                                Device: Laptop
                                Brand: lenovo T470s
                                type: 20JT-S04Y2L
                                SN: PC0LPH9U
                                Request: Repair
                                T470s Laptop (ThinkPad) - Type 20JT
                                • kulokutoys
                                  • Jun 2010
                                  • 132
                                  • Phillippines
                                  #58
                                  it removes the beep error but now on power cycle.
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    #59
                                    Serial Number :- PC0LPH9U
                                    Try a new one
                                    • kulokutoys
                                      • Jun 2010
                                      • 132
                                      • Phillippines
                                      #60
                                      Try a new one
                                      thanks but same response
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        Yesterday, 03:01 PM
                                        Lenovo ThinkPad T470s Notebook T Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad T470s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470s boardview and T470s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                        09-06-2024, 11:30 AM
                                        09-06-2024, 11:29 AM
                                        09-06-2024, 09:00 AM
