Lenovo ThinkPad T470s BIOS
  • huss584
    Hussein
    • Apr 2020
    • 230
    • Palestine
    Re: Lenovo ThinkPad T470s BIOS
    [QUOTE=hoaca388;1151370]
    Originally posted by huss584
    T470s (type 20HF, 20HG) Laptop (ThinkPad) - Type 20HG
    Serial number : PC0RYF1J
    Thank you for replaying, i try this file but notworking at all the all keyboard led flickering on time then, on the original file the device working well but there is problem when i make shutdown or restart i could not turn on until i press power up to 20 second the the device working well
    • huss584
      Hussein
      • Apr 2020
      • 230
      • Palestine
      Hello Sir,
      The Device working well i re-flash and detect that there is small IC beside the BIOS chip removed by mistakes
      after new BIOS you send it working well, i can restart and shutdown the turn on without problem
      Thank You Soooooooooooo much
      • Siuto
        • Aug 2022
        • A
        Lenovo T470s Bios
        Hi, I'm trying to update my laptop bios with a password and I don't care about data on disk.
        Laptop: Lenovo T470s
        Type 20JT-S0VY00
        Bios: 25Q128JVSQ
        Programmer: CH341APro
        Software: NeoProgrammer and AsProgrammer
        1. I read twice with incorrect chip configuration the Bios
        2. I compared them and were equals
        3. I patched with lenovo_autopatcher
        4. Write patched bios
        but I suppose that as I readed wrong on step 1, it will not work anymore.
        After that, I look on internet for a lot of different bios versions and write them without luck.
        What I'm doing wrong?
        How could I recover this laptop?
        Thanks in advance
        • hoaca388
          Badcaps
          • Jan 2022
          • 12368
          Re: Lenovo T470s Bios
          I don't think you misread the bios file, maybe writing the bios file to the chip is faulty if you use the CH341A with a clamp. Or you can try cleaning the ME area of the original file.
          Last edited by piernov; 08-28-2022, 05:39 AM. Reason: remove full quote of previous post
          • dopson
            • Nov 2021
            • 7
            • Belgium
            Hi Guys, can anybody help me to bring my t470s back to life?
            It is the model 20HG. I made a backup of BIOS (attached).
            The serial number is PC-0S6VCF.
            Very much appreciate any help.
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              #26
              Try this 16mb file. there is nothing to do with your 1mb EC.
              all donations are welcome,
              • hoaca388
                Badcaps
                • Jan 2022
                • 12368
                #27
                • dopson
                  • Nov 2021
                  • 7
                  • Belgium
                  #28
                  Hi Thx a lot, but it is not working ... I flash the bios, but when I plug the PSU, the power button light up for a moment and stays dead ... not possible to power up. From time to time the cooling fan turns on for a moment and then turns off. All BIOS files do the same behavior. I have used the NeoProgrammer with Ch341a and XGecu TL866II plus ... same result. Am I doing something wrong? Hopefully, I haven't destroyed the motherboard
                  Or should I desolder the bios chip for programming?
                  • dopson
                    • Nov 2021
                    • 7
                    • Belgium
                    #29
                    Thx a lot, same result as with the previous file
                    • dopson
                      • Nov 2021
                      • 7
                      • Belgium
                      #30
                      Hi Guys,
                      thx a lot, all is working now. The issue was on my side ... my soldering skills , accidentally desolder the diode close to BIOS chip, which provides the power to BIOS chip ... thx again, very much appreciate your help
                      • husnu16
                        • Jun 2020
                        • 122
                        • Türkiye
                        #31
                        hi master, please clear password my bios bin file.
                        T470s
                        type 20js-0021ge
                        sn: pc-0tb3x7
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12368
                          #32
                          [QUOTE=husnu16;1176331]
                          T470s
                          type 20js-0021ge
                          sn: pc-0tb3x7
                          Read this carefully : https://www.badcaps.net/forum/showthread.php?t=87588
                          • mferna14
                            • Jun 2018
                            • 1046
                            Try anyone of the zip attachments, all should work as they are in original form & only asked for P/W removal or not booting up fast... One Should work.
                            • trili
                              • Dec 2021
                              • 9
                              • CA
                              #34
                              I used a patched one and it displayed hardware id and I pressed enter and space bar a couple times and shut it off.
                              Can i flash it with any non patched bios now and it should work?
                              • mferna14
                                • Jun 2018
                                • 1046
                                This only I told you that copy a Non-Patched one.. I will check later whether I have one Non-patched in my database, will surely help you, np...
                                • mferna14
                                  • Jun 2018
                                  • 1046
                                  Here you go., this is an 100% Original - Non-patched BIOS Bin file for Lenovo Thinkpad 470s. It might be having a PW but works 100%...
                                  • kimolimo
                                    • Dec 2017
                                    • 7
                                    • marrakech
                                    #37
                                    Hi need bios t470s type;20jt-s10s00 sn pc-omgb47 thanks in advance
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12368
                                      #38
                                      Post your corrupted bios file and remember to write the correct serial number ( 0_ zero , O_ orange )
                                      • dahnking
                                        • Apr 2018
                                        • 264
                                        • kenya
                                        #39
                                        Thank you working
                                        • mehdiab17
                                          • Oct 2017
                                          • 56
                                          • algerie
                                          #40
                                          hello i want to repair my bios nm-b081 rev 1.0 t470s
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                            Lenovo ThinkPad T470s Notebook T Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad T470s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470s boardview and T470s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 11:30 AM
                                            09-06-2024, 11:29 AM
                                            09-06-2024, 09:00 AM
